jinky123
Message 1 of 15
BT FTTC connection constant re-syncing
I have an Huawei HG612 modem and I have my Billion 7800DXL router connected to it. I also use a Raspberry Pi to log stats from the modem and something isn't right with my line from the cabinet  approx < 500m away. Historically a tree in my neighbours garden wore through the telephone wires and my ADSL2 at the time died. This was fixed but the underlying issue of the branches wasn't corrected so it would only be a matter of time before the issue came to light again when the branches grew. My BT broad band hasn't been good for a while now, was supposed to be fixed a few months back. It is constantly re-syncing with a retrain: code of 2. In the past few days it has been very annoying with constant lost of internet every few hours or less. I log my external IP address also and this is constantly changing after every re-sync. In the last day it has re-synced with a new IP address see list :-
( Note: before these issues the connection was rock solid for months at a time but lately has been re-syncing randomly, only ever getting worse and more frequent ). Also note I have tried a couple of spare Huawei HG612 modems I have and they all display this re-syncing behaviour , which lead me to the conclusion that the issue is the line or cabinet equipment. ) Thank-you Jim
Re-syncing times
yesterday 21.30
yesterday 21:50
yesterday 22:40
Today 04.31
Today 06:30
Today 06:40
Today 10:50
14 REPLIES 14
Matt-S
Moderator-Retired
Message 2 of 15
Re: BT FTTC connection constant re-syncing
Hi @jinky123,
Welcome back to the Community and thanks for taking the time to post.
Sorry to hear that you are having problems with your connection.
I understand you are using a third-party hub put would you be able to post some sort of hub stats which would show the speeds you are getting and connection uptime etc?
Matt
jinky123
Message 3 of 15
# xdslcmd info --stats
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 2
Max: Upstream rate = 17660 Kbps, Downstream rate = 51960 Kbps
Path: 0, Upstream rate = 4293 Kbps, Downstream rate = 15000 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 21.6 18.1
Attn(dB): 0.0 0.0
Pwr(dBm): 12.2 5.3
VDSL2 framing
Path 0
B: 27 47
M: 1 1
T: 60 64
R: 16 16
S: 0.0592 0.3541
L: 5944 1446
😧 1101 91
I: 44 64
N: 44 64
Counters
Path 0
OHF: 302955 95399
OHFErr: 5 2
RS: 109063298 1131511
RSCorr: 5054 968
RSUnCorr: 1472 0
Path 0
HEC: 101 0
OCD: 0 0
LCD: 0 0
Total Cells: 46707951 0
Data Cells: 6970856 0
Drop Cells: 0
Bit Errors: 0 0
ES: 458 78
SES: 267 3
UAS: 2004 2004
AS: 1623
Path 0
INP: 11.50 4.00
PER: 5.32 16.99
delay: 16.00 8.00
OR: 72.04 28.24
Bitswap: 0 4
Total time = 1 days 6 hours 8 min 54 sec
FEC: 2318694 59919
CRC: 43087 292
ES: 458 78
SES: 267 3
UAS: 2004 2004
LOS: 120 2
LOF: 105 2
Latest 15 minutes time = 8 min 54 sec
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Previous 15 minutes time = 15 min 0 sec
FEC: 1131 153
CRC: 5 1
ES: 1 1
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Latest 1 day time = 6 hours 8 min 54 sec
FEC: 56936 6236
CRC: 6371 6
ES: 82 4
SES: 62 1
UAS: 464 464
LOS: 28 0
LOF: 32 0
Previous 1 day time = 24 hours 0 sec
FEC: 710913 22710
CRC: 20314 135
ES: 191 37
SES: 121 1
UAS: 1380 1380
LOS: 51 1
LOF: 50 1
Since Link time = 27 min 1 sec
FEC: 5054 968
CRC: 5 2
ES: 1 2
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
imjolly
Message 4 of 15
Have you used the test socket with filter to eliminate your master faceplate and internal wiring.  I assume you have but didn't say
certainly looks like tree/line problem as before
jinky123
Message 5 of 15
Yes tested with faceplate off and modem plugged into filter plugged into the master socket. Modem has now finally disconnected and I have no broadband now. I'm using my mobile phone data connection to answer your question. Regards
Jim
imjolly
Message 6 of 15
If you have no dial tone then report a phone fault to 151
jinky123
Message 7 of 15
There is a dial tone but no broadband connection. Quiet line test seems quiet as well. As I type this the Broadband has come back again.
Regards
Jim
imjolly
Message 8 of 15
If you have a dial  tone and no noise on your line then not the tree rubbing the cable problem
jinky123
Message 9 of 15
Ok but why would my  modem be constantly  re-syncing and broadband be coming and going and the retrain reason be 2, this is on the master socket with faceplate removed and a filter installed. There is something wrong either with line or cabinet equipment and I can't fix that. Note also I have tried another HG612 and an ECI  modem and it's the same symptoms of broadband  going away and then eventually re-syncing and then going away again.
My broadband has never really been right since it failed last time a few month back and was supposedly fixed, I just knew something wasn't right with all the random IP address changes which gradually got worse until the past few days where it's virtually unusable. So what do I do?
jinky123
Message 10 of 15
Well it gets worse , remember I have been at 45Mbps Down/ 13Mbps Up approx since I was connected to the new cabinet No9 years ago. Never had a problem now this is the latest data from the BT Wholesale website for my landline, see below.
Download speed achieved during the test was - 9.54 Mbps
 For your connection, the acceptable range of speeds
is 7.39 Mbps-10.55 Mbps .
 Additional Information:
 IP Profile for your line is - 10.55 Mbps
Also my last ticket for the issue is here https://community.bt.com/t5/BT-Fibre-broadband/Internet-goes-away-frequently/m-p/1954743#M290711 you can see its the same issue again. It began working again last time after the OpenReach engineers tinkered with stuff at the cabinet. So please get this fixed, I have spent hours gathering information both last time and now for this same problem. It isn't being fixed properly and I am still paying £60  quid a month for a connection that isn't working. As you can imagine it is inconvienient not having a connection, I would love to get this fixed.
Picture below (ignore scaling 500k is 50Mbps) is the start of the issue back at the end of May and you can see that the speed was a lot more than the 10Mbps I am capped at now.
