Message 1 of 2
BT Fibre 100, actually 150!
I get a full 150mb on 5mhz band but only half that on the 2.4mhz band. BT says thats right! I dont think so!
1 REPLY 1
Message 2 of 2
Re: BT Fibre 100, actually 150!
You think wrong.
Extract from speedguide.net
"Below is a breakdown of actual real-life average speeds you can expect from wireless routers within a reasonable distance, with low interference and small number of simultaneous clients:
802.11b - 2-3 Mbps downstream, up to 5-6 Mbps with some vendor-specific extensions.
802.11g - ~20 Mbps downstream
802.11n - 40-50 Mbps typical, varying greatly depending on configuration, whether it is mixed or N-only network, the number of bonded channels, etc. Specifying a channel, and using 40MHz channels can help achieve 70-80Mbps with some newer routers. Up to 100 Mbps achievable with more expensive commercial equipment with 8x8 arrays, gigabit ports, etc.
802.11ac - 100+ Mbps typical, higher speeds (300+ Mbps) possible over short distances without many obstacles, with newer generation 802.11ac routers, and client adapters capable of multiple streams."
