Message 1 of 38
BT Fibre 2 Uploadspeed?
Hi, I recently got a order with BT for the BT Fibre 2 Package and with the confirmation email of speeds etc it shows my estimated upload should be 8-9mbs? Only problem i have with that is that Sky currently gives me 17mbs upload? If anyone knows if this is just an estimate or something?
37 REPLIES 37
Message 2 of 38
Re: BT Fibre 2 Uploadspeed?
Enter your phone number and post results. Remember delete number.
Message 3 of 38
Hi, Thanks for the reply. The number i checked currently doesn't allow me to do the phone number test, But it allows me to do the address one. Is that fine?
Message 4 of 38
DJ4ytf8
Message 5 of 38
You probably need to progress the order and when complete then try 0800800030 and upgrade to fibre 2
Fibre 2 is certainly available but maybe problem with your phone number
Message 6 of 38
I should probably have clarified, I'm adding an additional phone line for another broadband (Currently have sky for the rest of the people in my house) I completed the order via phone with a salesman and the email/tracking my order shows BT Fibre 2, After checking the the email about the engineer coming out to fit the phone line etc i noticed it only shows 8-9mbps estimated upload speed. I'm not sure how that's possible when i'm currently getting 16-18mbps upload via sky?
Message 7 of 38
You should get between 75/57mb down sspeed according to dslchecker results   the SKY  speeds appear to be adsl2 connection not FTTC
Message 8 of 38
So how do i know if the BT Fibre 2 will be FTTC or not?
Thanks!
Message 9 of 38
You can see what is available from the dslchecker - VDSL connection.
Did you make sure BT were aware this was a new line not takeover of existing SKY connection
Message 10 of 38
This is what my order summary states;
Fibre 2
Status: Add
I was sure to tell them that this is an additional line that would be installed for the internet, What i don't understand is i thought that BT would be the decider of if the phone line was VDSL or ADSL? New to this whole thing as i've never looked into this before. Appreciate it!
