Hi @Madhouse,
Thanks for getting in touch.
I've dropped you a private message to get this sorted for you.
DanielS
I am also seeing the upload issue since the latest firmware download is also slower than it was before the firmware upgrade
I’m on the 910/110 tier
can I get some help please
Sure thing @PC1977,
We can look into the upload not being on the right profile but you'll need to speak with the FTTP team for help around the download speeds.
I've dropped you a private message too.
DanielS
Thank you @PC1977, I appreciate that.
Between the two of us, we will get this all sorted for you.
DanielS
Hi Daniel ,
Sorry if this is the wrong place to post but I too have just upgraded to Fibre 900, whilst I am sort of happy with the d/l speeds I have the same problem as others, only 50meg upload speed.
Firmware version:
v0.17.01.12312-BT
Firmware updated:
21-Jun-2020
Serial number:
+091300+1835001442
I have tried a factory reset. Do you require any more info and can you help ?
Thanks Phill
Hi @Phillm.
Thanks for posting. Can you send your details over please? I've dropped you a private message so you can get in touch.
Cheers
David
Hi,
I don't know if you had a chance to look and sort something but it seems the issue has been resolved. I am now getting the speeds I was promised. Thank you for your time and patience.
Kind Regards
Phill
