DanielS
Moderator
Moderator
Message 661 of 954
Re: BT Fibre 900 Upgrade / Smart Hub 2 upload throttling
Hi @Madhouse,
Thanks for getting in touch.
I've dropped you a private message to get this sorted for you.
DanielS
PC1977
Message 662 of 954
@DanielS
I am also seeing the upload issue since the latest firmware download is also slower than it was before the firmware upgrade
I’m on the 910/110 tier
can I get some help please
DanielS
Moderator
Moderator
Message 663 of 954
Sure thing @PC1977,
We can look into the upload not being on the right profile but you'll need to speak with the FTTP team for help around the download speeds.
I've dropped you a private message too.
DanielS
PC1977
Message 664 of 954
@DanielS
Hi Daniel, I have replied to your message
i will give the FTTP team a call tomorrow
DanielS
Moderator
Moderator
Message 665 of 954
Thank you @PC1977, I appreciate that.
Between the two of us, we will get this all sorted for you.
DanielS
PC1977
Message 666 of 954
@DanielS
Excellent
Phillm
Message 667 of 954
@DanielS
Hi Daniel ,
Sorry if this is the wrong place to post but I too have just upgraded to Fibre 900, whilst I am sort of happy with the d/l speeds I have the same problem as others, only 50meg upload speed.
Firmware version:
v0.17.01.12312-BT
Firmware updated:
21-Jun-2020
Serial number:
+091300+1835001442
I have tried a factory reset. Do you require any more info and can you help ?
Thanks Phill
DavidM
Moderator
Moderator
Message 668 of 954
Hi @Phillm.
Thanks for posting. Can you send your details over please? I've dropped you a private message so you can get in touch.
Cheers
David
Phillm
Message 669 of 954
Re: BT Fibre 900 Upgrade / Smart Hub 2 upload throttling..... Update
Hi,
I don't know if you had a chance to look and sort something but it seems the issue has been resolved. I am now getting the speeds I was promised. Thank you for your time and patience.
Kind Regards
Phill
DavidM
Moderator
Moderator
Message 670 of 954
No problem @Phillm. I think it was @JohnC2 who picked that up.
Cheers
David
