Judge626
Message 741 of 1,489
Re: BT Fibre 900 Upgrade / Smart Hub 2 upload throttling..... Update
@jamie1985 out of curiosity, what's your router firmware version? I started having issues again after the latest update.
m4rks
Message 742 of 1,489
I'm also getting 800-910 download but only a 50mb upload, is it just John that can help fix this or is there anyone else monitoring the forum? Looks like John isn't in at the moment.
DanielS
Moderator
Moderator
Message 743 of 1,489
Hi @m4rks,
Thanks for getting in touch.
I've sent you a private message about this.
DanielS
verdan28
Message 744 of 1,489
I had this resolved in July and have been steady, but now back to 10mbps upload.
You need to sort this out permanently as I don’t want to have to keep coming here to get this resolved every 6 months.
domwells
Message 745 of 1,489
My upload has been 110mpbs since installation but  is now capped at 50mbps, what's the best way to get it resolved?
Judge626
Message 746 of 1,489
Thanks to the mod team again for getting this fixed...speeds as expected again. I just pray i'm not here again in 3 months after the next firmware update.
3286212510505183-EFqtPDXS
Not sure if a mod can answer but is there any compensation as was at sub 10% of my upload speed for 14 days.
pippincp
Message 747 of 1,489
@Judge626  There's no guarantee on upload speeds.
Judge626
Message 748 of 1,489
I thought as much, it's disappointing as I have the connection more for the fast upload as opposed to the download. I'd take a 100Mb download if I could still have the 100Mb+ upload.
Barneyabz
Message 749 of 1,489
Upload speed fixed, back at 100mbit+
Thanks to the mods for getting this fixed.  Fingers crossed it doesn't go again.
BT Full Fibre 900
busterboy1
Expert
Message 750 of 1,489
@Barneyabz
_________________________________________________________________________________
May I ask, all these upload fixes that the Mods are applying, Does this just apply to the Smart Hub 2 or is anyone with third party routers having issues as well.
___________________________________________________________________________________________
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
