Message 1 of 2
BT Fibre connection details
Hi All. Quick question; if you're connecting a 3rd party router to the Openreach ONT does it matter is you use either bthomehub@btinternet.com or bthomehub@btbroadband.com as the username?
1 REPLY 1
Message 2 of 2
Re: BT Fibre connection details
