Message 1 of 5
BT Full Fibre with Apple Time Capsule
Hi all,
Finally after many years, full fibre (FTTP) is availabel in our area and we are due to be connected mid March. Currently we have a SmartHub 2 (wifi has been turned off) connected to a Apple Time Capsule that i'm using for my router. Will I be able to use my Time Capsule with FTTP?
4 REPLIES 4
Message 2 of 5
Re: BT Full Fibre with Apple Time Capsule
Yes, nothing will change.
If you don't require Digital Voice, you don't even need to use the Smart Hub 2 if you don't want to, just connect the Apple Time Capsule directly to the ONT.
Message 3 of 5
Perfect, we do not have a home phone. so am I right in the thinking the new ONT is like the old white openreach modems from years ago?
Message 4 of 5
Yes, exactly that.
Message 5 of 5
Thank you 👍
