NewtronStar
Expert
Message 61 of 138
Re: BT G.INP?
I would read the Kitz forum regarding G.INP it would quickly put the ECI modem/cabinet debate to bed.
http://forum.kitz.co.uk/index.php/topic,15190.0.html
Distinguished Guru
Message 62 of 138
Re: BT G.INP?
Does it? It seems to leave more questions AFAICS
If not, I'll try again 🙂
dlmfun
Message 63 of 138
Re: BT G.INP?
i dont undertsand how g.inp works? is it basically another form of dlm or does it work along side dlm? and how is it possible to tell if g.inp is active.
Sage
Sage
Message 64 of 138
Re: BT G.INP?
Read the article linked to in post 58.
Distinguished Guru
Message 65 of 138
Re: BT G.INP?
It seems to be an alternative to Interleaving and INP. If a data packet is damaged by noise then the damaged bits are retransmitted down a separate data channel and it is repaired on the fly.
dlmfun
Message 66 of 138
Re: BT G.INP?
i get what you mean, guess it would make dlm less likely to kick in at that rate then, i wonder if my dlm was triggered by g.inp because whenever i had dlm on before, i was still getting crc errors aswell as fec errors and today ive not had one single crc error and thats never happened in the 8 or 9 months ive been checking.
Distinguished Guru
Message 67 of 138
Re: BT G.INP?
If you can see CRCs and FECs surely you can see if G.INP is active?
dlmfun
Message 68 of 138
Re: BT G.INP?
ive  just read some info on that link that tells you about it and it says that with g.inp on, it will say bearer 0 and bearer 1 in the modem stats.
Sage
Sage
Message 69 of 138
Re: BT G.INP?
That's correct. Do you see them?
dlmfun
Message 70 of 138
Re: BT G.INP?
my modem doesnt show the bearer part but the guy who posted the info in the link said he used dslstats software and maybes thats the only way to get it to show, maybe it shows all the added info that doesnt usually show within the modem stats.
