Simon856hg
Message 1 of 19
BT HH5 Dropping Conection and Speed all Over
Hello All
Im looking for help with my HH5 since the 29th of December It has been playing up.
Dropping out , Dropping speeds etc. I have reported it six times and each time it tells
me the fault is with the exchange end. 37Mbps for 4years not one problem now its
going nuts. I went on speed checker it fluctuated between 38mbps & 5.6Mbps as
the test was been performed. Cold weather seems to upset it too.
As I write this it went off at 19.03 - 19.59 - 20.11 -20.24 - 20.37 and i keep having to start again.
Exchange CHORLEY is served by Cabinet 7
***PERSONAL DETAILS REMOVED***
none of the above are fixed .
hub stats
1. Product name: BT Home Hub
2. Serial number: +068343+NQ34231533
3. Firmware version: Software version 4.7.5.1.83.8.222.1.1 (Type A) Last updated 23/02/16
4. Board version: BT Hub 5A
5. DSL uptime: 0 days, 00:06:22
6. Data rate: 6000 / 34956
7. Maximum data rate: 6835 / 43802
8. Noise margin: 14.6 / 10.1
9. Line attenuation: 24.4 / 23.6
10. Signal attenuation: 24.3 / 21.2
11. Data sent/received: 350.0 MB / 4.8 GB
12. Broadband username: bthomehub@btbroadband.com
18 REPLIES 18
Simon856hg
Message 2 of 19
Re: BT HH5 Dropping Conection and Speed all Over
TR069 LOG From my HH5
Recorded events
Time and date Message
22:51:35, 09 Feb.( 6391.550000) CWMP: session completed successfully
22:51:35, 09 Feb.( 6391.360000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
22:51:28, 09 Feb.( 6384.800000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
22:51:28, 09 Feb.( 6384.790000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
22:50:38, 09 Feb.( 6334.830000) CWMP: session closed due to error: No response
22:50:38, 09 Feb.( 6334.810000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
22:50:38, 09 Feb.( 6334.800000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
22:50:08, 09 Feb.( 6304.330000) CWMP: session closed due to error: No response
22:50:05, 09 Feb.( 6301.980000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
22:50:05, 09 Feb.( 6301.970000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
22:50:05, 09 Feb.( 6301.500000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
22:43:05, 09 Feb.( 5881.620000) CWMP: session completed successfully
22:43:05, 09 Feb.( 5881.450000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
22:42:59, 09 Feb.( 5875.030000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
22:42:59, 09 Feb.( 5875.020000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
22:42:08, 09 Feb.( 5824.290000) CWMP: session closed due to error: No response
22:42:08, 09 Feb.( 5824.270000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
22:42:08, 09 Feb.( 5824.260000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
22:41:37, 09 Feb.( 5793.800000) CWMP: session closed due to error: No response
22:41:34, 09 Feb.( 5790.700000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
Seems to be doing the same thing over and over
HH5 @ 23.15 on 09/02/17
1. Product name:BT Home Hub
2. Serial number:+068343+NQ34231533
3. Firmware version:Software version 4.7.5.1.83.8.222.1.1 (Type A) Last updated 23/02/16
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 00:01:28
6. Data rate:6000 / 34956
7. Maximum data rate:6743 / 44195
8. Noise margin:6.6 / 10.4
9. Line attenuation:24.4 / 23.6
10. Signal attenuation:24.2 / 21.2
11. Data sent/received:31.7 MB / 583.1 MB
Simon856hg
Message 3 of 19
HH5 @ 23.39 ON 09/02/17
5. DSL uptime:0 days, 00:08:08
7. Maximum data rate:6831 / 44127
8. Noise margin:14.7 / 10.4
11. Data sent/received:32.4 MB / 584.8 MB
Simon856hg
Message 4 of 19
Still having isues ok untill 22.40  10.02.17.
?Question why is the time always diffrent when it drops out?
22:40:56, 10 Feb.(19420.870000) PTM over DSL is down after 322 minutes uptime
22:40:56, 10 Feb.(19420.870000) PPPoE is down after 321 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
22:40:51, 10 Feb.(19416.620000) PPP LCP Send Termination Request [User request]
18:19:09, 10 Feb.( 129.300000) WAN operating mode is VDSL
18:19:09, 10 Feb.( 129.300000) Last WAN operating mode was VDSL
18:19:07, 10 Feb.( 127.950000) PPP IPCP Receive Configuration ACK
18:19:07, 10 Feb.( 127.820000) PPP IPCP Send Configuration Request
18:19:07, 10 Feb.( 127.820000) PPP IPCP Receive Configuration NAK
18:19:07, 10 Feb.( 127.820000) PPP IPCP Send Configuration ACK
18:19:07, 10 Feb.( 127.820000) PPP IPCP Receive Configuration Request
18:19:07, 10 Feb.( 127.610000) PPP IPCP Send Configuration Request
18:19:06, 10 Feb.( 126.440000) PPPoE is up -​ Down Rate=34956Kbps, Up Rate=6000Kbps; SNR Margin Down=10.4dB, Up=6.6dB
18:19:06, 10 Feb.( 126.430000) CHAP authentication successful
18:19:06, 10 Feb.( 126.190000) CHAP Receive Challenge
18:19:06, 10 Feb.( 126.190000) Starting CHAP authentication with peer
18:19:06, 10 Feb.( 126.190000) PPP LCP Receive Configuration ACK
18:19:06, 10 Feb.( 126.070000) PPP LCP Send Configuration Request
18:19:06, 10 Feb.( 126.070000) PPP LCP Receive Configuration Reject
18:19:05, 10 Feb.( 125.950000) PPP LCP Send Configuration ACK
18:19:05, 10 Feb.( 125.950000) PPP LCP Receive Configuration Request
18:19:05, 10 Feb.( 125.950000) PPP LCP Send Configuration Request
18:18:15, 10 Feb.( 75.460000) PTM over DSL is up
18:17:33, 10 Feb.( 33.460000) WAN Auto-​sensing running.
14:20:26, 10 Feb.( 134.370000) WAN operating mode is VDSL
14:20:26, 10 Feb.( 134.370000) Last WAN operating mode was VDSL
14:20:25, 10 Feb.( 133.100000) PPP IPCP Receive Configuration ACK
14:20:25, 10 Feb.( 132.930000) PPP IPCP Send Configuration Request
14:20:25, 10 Feb.( 132.930000) PPP IPCP Receive Configuration NAK
14:20:25, 10 Feb.( 132.850000) PPP IPCP Send Configuration ACK
14:20:25, 10 Feb.( 132.850000) PPP IPCP Receive Configuration Request
14:20:25, 10 Feb.( 132.680000) PPP IPCP Send Configuration Request
14:20:24, 10 Feb.( 131.570000) PPPoE is up -​ Down Rate=34956Kbps, Up Rate=6000Kbps; SNR Margin Down=10.6dB, Up=6.7dB
14:20:24, 10 Feb.( 131.560000) CHAP authentication successful
14:20:23, 10 Feb.( 131.280000) CHAP Receive Challenge
14:20:23, 10 Feb.( 131.280000) Starting CHAP authentication with peer
Simon856hg
Message 5 of 19
10.02.17    23.15
5. DSL uptime:0 days, 00:15:57
7. Maximum data rate:6807 / 44192
8. Noise margin:6.5 / 10.4
11. Data sent/received:178.0 MB / 2.6 GB
Also in event log- system  4 dns errors (event id 1014).
Simon856hg
Message 6 of 19
Here we go again....... orange light flashing sinse 15.30 - 17.00     12.02.17
 BT infinity2 unlimited
5. DSL uptime:0 days, 00:08:50
6. Data rate:5993 / 33478
7. Maximum data rate:6992 / 42143
8. Noise margin:7.4 / 9.3
9. Line attenuation:36.9 / 23.2
10. Signal attenuation:24.4 / 20.8
11. Data sent/received:0.8 MB / 4.2 MB
12. Broadband username:bthomehub@btbroadband.com
Distinguished Guru
Distinguished Guru
Message 7 of 19
Try a quiet line test 17070 option 2.
Simon856hg
Message 8 of 19
Tried the quiet line test , i cant hear anything ....
Simon856hg
Message 9 of 19
a lot of PTM OVER DSL downs and ups
Simon856hg
Message 10 of 19
As you can see here when it went down the time and date change to October.
Recorded events
01:00:22, 09 Oct.( 38.400000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
01:00:22, 09 Oct.( 38.390000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE'
01:00:22, 09 Oct.( 37.820000) CWMP: Initializing transaction for event code 1 BOOT
15:29:26, 12 Feb.(22634.040000) CWMP: session closed due to error: No response
15:29:26, 12 Feb.(22634.010000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
15:29:26, 12 Feb.(22634.010000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
15:29:17, 12 Feb.(22624.760000) PTM over DSL is up
15:28:56, 12 Feb.(22603.510000) CWMP: session closed due to error: No response
15:28:53, 12 Feb.(22600.730000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
15:28:53, 12 Feb.(22600.720000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
15:28:53, 12 Feb.(22600.250000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
15:28:47, 12 Feb.(22595.060000) PTM over DSL is down after 4 minutes uptime
15:28:47, 12 Feb.(22595.040000) PPPoE is down after 3 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
15:28:43, 12 Feb.(22590.690000) PPP LCP Send Termination Request [User request]
15:26:57, 12 Feb.IN: BLOCK [9] Packet invalid in connection (tcp reset attack is suspected: TCP [31.13.90.37]:443-​>[86.179.152.239]:32895 on ppp3)
15:26:57, 12 Feb.BLOCKED 2 more packets (because of Packet invalid in connection)
