Appologies, i have this socket as the master
And this socket is an extention
I have just done another speed test and now have 16mb dowload. Here is my HH details
1. Product name: | BT Home Hub |
2. Serial number: | +068343+NQ52515889 |
3. Firmware version: | Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 03/09/15 |
4. Board version: | BT Hub 5A |
5. DSL uptime: | 0 days, 00:08:14 |
6. Data rate: | 5021 / 30996 |
7. Maximum data rate: | 5021 / 31315 |
8. Noise margin: | 6.2 / 6.3 |
9. Line attenuation: | 33.9 / 28.5 |
10. Signal attenuation: | 34.1 / 24.6 |
11. Data sent/received: | 1.2 GB / 44.0 GB |
12. Broadband username: | bthomehub@btbroadband.com |
13. BT Wi-fi: | Yes |
14. 2.4 GHz Wireless network/SSID: | BT HH 2Ghz |
15. 2.4 GHz Wireless connections: | Enabled (802.11 b/g/n (up to 144 Mb/s)) |
16. 2.4 GHz Wireless security: | WPA2 |
17. 2.4 GHz Wireless channel: | Automatic (Smart Wireless) |
18. 5 GHz Wireless network/SSID: | BT HH 5Ghz |
19. 5 GHz Wireless connections: | Enabled (802.11 a/n/ac (up to 1300 Mb/s)) |
20. 5 GHz Wireless security: | WPA2 |
21. 5 GHz Wireless channel: | Automatic (Smart Wireless) |
22. Firewall: | Default |
23. MAC Address: | a0:1b:29:53:3a:84 |
24. Modulation: | G.993.2 Annex B |
25. Software variant: | AA |
26. Boot loader: | 1.0.0 |
I have not altered any wires behind my master socket faceplate but i have jst looked and there is a wire going to every terminal. I dont want to cut any wires as i have no idea what im doing and dont want to loose connection altogether.
if you have the NTE5 as the master - one where bottom hjave comes off - then you only need wires conencted to terminals 2&5 and the rest are not required especially the wire(s) conencted to terminal 3. this should be disconencted you don't need to cut it and should be removed form terminal 3 in all sockets - as explained here
Hi,
I have disconected the bell wire and rebooted my HH. Download speed currently at 16mb.
Here is my hub stats.
according to stats you have a 31.8mb connection speed with noise margin about normal at 6.2db. now see it after your changes thes hub remains stable
Many thanks for your help. I willl keep an eye on it over the next few days and update you.
Hi Imjolly,
Just a quick update. I have been keeping any eye on my connection since removing the bell wire.
My connection seems to be hovering arouund 28 to 30mb Since the removal of the wire i have not seen my download speed drop below 20mb.
The HH5 does not seem to be rebooting its self as much either. Current Uptime 1 day 4 hours
I think you have solved my issue - Thank You so much for taking the time to reply to me and for your advice.
I wish you all the best
Thank You 🙂
thanks for update
if it starts dropping conenction again then post back
