Hi,
I'm coming here as I've raised 3 faults with BT so far but the issue hasn't been resolved. For some reason the faults keep getting closed without without any communication with myself to check if it's fixed.
For as long as I remember the router occassionally resets by itself, it feels like this is happening more frequently and the logs show it's happening once or twice a day. I'm not sure if it's an issue with the line or the router.
Below is an extract from the WAN log, this cycle repeats itself:
21:31:47, 14 Feb. | (512319.620000) PPPoE is down after 1226 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -? Down)] |
21:31:43, 14 Feb. | (512315.370000) PPP LCP Send Termination Request [User request] |
01:05:21, 14 Feb. | (438735.910000) WAN operating mode is VDSL |
01:05:21, 14 Feb. | (438735.910000) Last WAN operating mode was VDSL |
01:05:20, 14 Feb. | (438734.710000) PPP IPCP Receive Configuration ACK |
01:05:20, 14 Feb. | (438734.710000) PPP IPCP Send Configuration Request |
01:05:20, 14 Feb. | (438734.700000) PPP IPCP Receive Configuration NAK |
01:05:20, 14 Feb. | (438734.700000) PPP IPCP Send Configuration ACK |
01:05:20, 14 Feb. | (438734.690000) PPP IPCP Receive Configuration Request |
01:05:20, 14 Feb. | (438734.690000) PPP IPCP Send Configuration Request |
01:05:19, 14 Feb. | (438733.660000) PPPoE is up -? Down Rate=69511Kbps, Up Rate=16272Kbps; SNR Margin Down=3.1dB, Up=6.0dB |
01:05:19, 14 Feb. | (438733.640000) CHAP authentication successful |
01:05:18, 14 Feb. | (438733.500000) CHAP Receive Challenge |
01:05:18, 14 Feb. | (438733.500000) Starting CHAP authentication with peer |
01:05:18, 14 Feb. | (438733.490000) PPP LCP Receive Configuration ACK |
01:05:18, 14 Feb. | (438733.490000) PPP LCP Send Configuration Request |
01:05:18, 14 Feb. | (438733.480000) PPP LCP Receive Configuration Reject |
01:05:18, 14 Feb. | (438733.480000) PPP LCP Send Configuration ACK |
01:05:18, 14 Feb. | (438733.480000) PPP LCP Receive Configuration Request |
01:05:18, 14 Feb. | (438733.480000) PPP LCP Send Configuration Request |
01:04:28, 14 Feb. | (438682.950000) PTM over DSL is up |
01:03:53, 14 Feb. | (438647.700000) PTM over DSL is down after 958 minutes uptime |
01:03:53, 14 Feb. | (438647.700000) PPPoE is down after 957 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -? Down)] |
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
are you using the test socket to see if that stabilises your conenction by eliminating your internal wiring and faceplate
Thanks for the replies.
I don't have a landline phone, I will see if I can get hold of one to test.
I wasn't aware of a test socket but have just googled to see what it is, I should be able to test this easily enough
I will report back when I've had a chance to action these suggestions.
you will need to use a filter and leave it conencted for a few days if possible
Please read Why do I need a landline phone?
You will need to connected to BT Broadband to access this link, and any other links I post.
