jonmale
Message 1 of 20
BT Homehub & Hub phone - what happens to them if I move to BT Infinity
Hi there,
I wonder if you can answer these questions:
If I move to Infinity what will happen to my BT Hub phone (and the 056... number)?
What will happen to my Hub (version 2)?
Presumably it will be replaced with the newer v3 Hub.  I believe the Hub phone has been discontinued now, so the v3 Hub doesn't have a phone dock - although the pictures for Infinity show a stand-alone phone/dock.
Thanks!
19 REPLIES 19
Ratty2012
Recognised Expert
Message 2 of 20
Re: BT Homehub & Hub phone - what happens to them if I move to BT Infinity
@jonmale wrote:
Hi there,
Thanks!
BT talk has been discontinued and is not provided with Infinity so your Hub phone and number will no longer work with Infinity.
Message 3 of 20
You will loose your BT BB Talk number if you move to Infinity as the service is not compatable with the hub.
However, many on here with hub 3 have asked to keep it as BT Softphone does work with hub 3, so too does BT BB Talk work on a smartphone using the Sipdroid app.  BT Smart Talk seems to be the intended replacement for BT BB Talk.
Not a popular move with many of us; taking away one very distinctive feature of BT Broadband.
BB Talk will be phased out come what may sad to say :smileymad:
AQ.
"Welcome to Royston Vasey - You'll never leave."
Message 4 of 20
You will lose your Broadband Talk number, but you can still use the hub phones, provided you keep hold of your old home hub.
This diagram shows how.
Using your old BT Hub Phones with your Home Hub 3 - Infinity  Version
Message 5 of 20
@Ratty2012 wrote:
@jonmale wrote:
Hi there,
Thanks!
Not discontinued quite yet, as many of us are still using it with hub 3...............:smileywink:
AQ.
Ratty2012
Recognised Expert
Message 6 of 20
@AllanQuatermain wrote:
@Ratty2012 wrote:
@jonmale wrote:
Hi there,
Thanks!
It has been discontinued to new customers
jonmale
Message 7 of 20
Thanks for the rapid replies guys!
I got that impression. I have to get my head round what SmartTalk is all about. Guess it's a similar type of thing to Skype - making phonecalls thru the web?
I could never really get my head round BB Talk (despite being technically minded)!
I just loved/love the design (asthetics) of the Hub and phone.
Message 8 of 20
correct but not to existing BT customers who still have the service active and as posted there are work round even with infinity
jonmale
Message 9 of 20
Thanks for that. So the old Hub will effectively 'daisychain' to the new Hub 3? I presume the phone handset will only act as a regular phone?
Message 10 of 20
Yes, that is correct. All you will be using the old home hub for, is a DECT base station.
It quite useful if you have more than one hub phone, as it saves buying new cordless handsets
