NorthEasterner
Message 1 of 12
BT Hub 5 Type B
Hi,
Has anyone managed to get a hub 5 type B? Just wondering if it's any use buying one as there is one on an auction site for £70
What's the difference as it says on the listing it is better than the hub 5 type a and wasn't sure? Help appreciated 🙂
11 REPLIES 11
Barry57
Expert
Message 2 of 12
Re: BT Hub 5 Type B
I wouldn't recommend it
There are no soild reports of it fixing the disconnection issues.
Message 3 of 12
Re: Thread on deleted posts
If you really want a Homehub 5, have you checked out the forum for the problems it seems to have, you can get a brand new one without a broken leg from BT for £45
http://bt.custhelp.com/app/answers/detail/a_id/35097/~/how-can-i-get-a-new-bt-home-hub%3F
NorthEasterner
Message 4 of 12
Re: BT Hub 5 Type B
I'm from Sunderland not Newcastle LOL!!
I was sort of put off when I saw item location as Newcastle Smiley Surprised
NorthEasterner
Message 5 of 12
Although it wouldn't be guaranteed a hub 5 type b.
Not bothered about the broken leg as it will be on a shelf and won't be noticed that much 😕
Message 6 of 12
Re: BT Hub 5 Type B
You should remove the link to the hub that you have posted. It's against forum rules and will be removed by the moderators.
EDIT: As far as I am aware there is no difference between the A & B other than different manufactures and different software but they both do the same job with the same specs.
Message 7 of 12
Re: BT Hub 5 Type B
correct GG no operational differences between the A&B
Message 8 of 12
Re: BT Hub 5 Type B
You will need to remove the link altogether. You can not provide a link to a commercial site.
NorthEasterner
Message 9 of 12
Re: BT Hub 5 Type B
MOD removed link
(I thought it was a free world)
I've decided to wait a bit longer to see if there is a cheaper hub 5 type B
Message 10 of 12
Re: BT Hub 5 Type B
the forum has t&c and only open to members to post. you agreed the T&C when you joined the forum  so not an open forum in that anyone can post but open that anyone can read all the posts
