signetone
Message 1 of 8
BT Hub 6
I am having trouble with the BT Hub 6.
The broadband is testing fine to the hub but I am finding the 5Ghz signal from the hub is fine but from the hub only?
there is no signal on it - yet the 2.4 Ghz is working fine.
so the ipad and iphone log onto the hub and then have no signal at all, but an older imac and a sony mobile test and work perfect and run a speed check.
I can change back to my old Hub 5 and prove this.
Can i do a reset to the hub 6 that may solve this issue but not wanting me to log every device back ointo the hub 6.
which is getting a huge task with lots wifi devices these days and hubs (sonos and Hue) plus nest devices.
Help would be appreciated.
I have not split the 5 and 2.4 for information.
Brian
7 REPLIES 7
imjolly
Message 2 of 8
Re: BT Hub 6
Turn off smart setup and split the 2.4/5ghz networks as many devices don't like them combined
signetone
Message 3 of 8
Re: BT Hub 6
Thanks will try that
signetone
Message 4 of 8
Re: BT Hub 6
I followed that advice.
The 5 on the split does not have broadband but does have a signal to the router. BT are sending a replacement router tomorrow.
I could try a hard restart before changing over. Though this is just more work. The issue only started the other morning.
imjolly
Message 5 of 8
Re: BT Hub 6
I would just wait for new hub  if you have a lot of wifi devices in use then when new hub arrives
turn off smart setup
split the 2.4/5 ghz networks and select channel manually
change SSID for 2.4 and 5ghz to the same as previous hub and use same password then all wifi devices should connect without any changes - save lot of effort
signetone
Message 6 of 8
Re: BT Hub 6
Thank-you will do that.
Can you explain what I need to do after
‘split the 2.4/5 ghz networks and select channel manually’
It’s the select manually part?
Thanks for your great advice.
Should save loads time.
signetone
Message 7 of 8
Re: BT Hub 6
The new hub arrived.
Configured as recommended and it’s great.
Thanks for advice.
imjolly
Message 8 of 8
Re: BT Hub 6
once you have split the networks by toggling the switch then go to 2.4 channel and select one of channels and take of auto then repeat for 5ghz channel
