Druid111
Newbie
Message 1 of 6
BT Hub flashing pink
Hi need some advice, have called BT twice today as since 12 noon my hub has been flashing pink. Have been connected to Call centre in India somewhere, have checked all cables, reset hub, performed factory reset, still nothing. Being told I will have to wait for an engineer to call on the 30th October! yikes my kids are so very unhappy, especially as they have a mass of A-level homework to complete!
I have also called 1470 17070 and it has announced my number completely, have been with BT since May/June this year, appalled with service to begin with but stuck in a contract now. Was also warned that if the engineer found no fault I would be charged in excess of £100 plus VAT.
Any advice.
Regards
5 REPLIES 5
Message 2 of 6
Re: BT Hub flashing pink
Did you also try connecting to the test socket to eliminate any problems caused by internal wiring?
Message 3 of 6
There is no charge if no fault is found there is a charge if the fault is caused by a fault is found on your internal wiring or equipment connected to it
Druid111
Newbie
Message 4 of 6
Hi there have checked the test socket and our phone is working normally, called out and received call. Will just wait and see what the engineer says in a week's time.
Druid111
Newbie
Message 5 of 6
Oh and many thanks for both of your replies.
Much appreciated.
Kind regards
Message 6 of 6
Have you tried connecting your hub to test socket with a filter and see if that makes a broadband connection
