Message 11 of 20
Re: BT Infinity 2: 5 mps?! :(
@licquorice wrote:
What does the hub show as modulation type? (Further down the list on the stats I think)
That 448Kbs, does look suspiciously like ADSL Max and not VDSL.
Message 12 of 20
Indeed, that was my thinking.
Message 13 of 20
Although the max data rate is higher. I think its a connection issue, like using a microfilter in a filtered socket, or plugging into a filtered extension socket. The engineer could not upload the results to the server, if they were wrong.
ale_b
Message 14 of 20
Message 15 of 20
You are still on ADSL (normal broadband), not BT Infinity. There is no way the engineer could have measured that speed at your house.
Did they actually visit, or did they just ring to say you are getting 40Mbs?
Message 16 of 20
Yep, as suspected.
Message 17 of 20
I have flagged this up to the moderators, otherwise you are going to be given the runaround, if you complain to the helpdesk, as 10 days are not going to make any difference.
ale_b
Message 18 of 20
Thank you!
It's so frustrating! I've also asked the guy "Are you sure that it's the fibre working and not the old broadband?" :((
Message 19 of 20
Thank you!
That seems a bit naughty. Hopefully the modertors will pick this one up. I cannot see how he could have uploaded the results to the BT server, as that is neede to complete the job?
Moderator
Moderator
Message 20 of 20
@ale_b I'm really sorry about this, it's clear from your router stats that you're still on ADSL broadband. If you send over your details we'll be happy to help. You can find the 'click here to contact the mods' link by clicking on my username.
Neil
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
