cagey1two3
Message 1 of 5
BT Infinity 2 Connection and speed drops.
Hi all, I have been recently experiencing BB cutouts and speed drops.
I have had Infinity 2 connected since last July and my speed and connections had been stable. I was previously getting a consistant DL speed of 74Mbps and an UL speed of 18Mbps. I have recently noticed that my DL speed has been dramatically reduced and is currently at 46 Mbps with little change to my UL speed which is 17.27 Mbps.
I seem to be experiencing regular disconnects.
These are my current stats
Downstream sync speed:
46.76 Mbps
 Upstream sync speed:
17.27 Mbps
 Network uptime:
0 Days, 16 Hours 30 Minutes
 System uptime:
9 Days, 3 Hours 40 Minutes
Product name:
BT Hub 6A
Serial number:
+084316+NQ71503284
Firmware version:
SG4B1000B540
Firmware updated:
24-May-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 16 Hours 21 Minutes 49 Seconds
Data rate:
17.27 Mbps / 46.76 Mbps
Maximum data rate:
17185 / 46434
Noise margin:
4.7 dB / 5.8 dB
Line attenuation:
11.6 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
12467 MB Uploaded / 30240 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-HCP7
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-HCP7
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
F4:6B:EF:19:4D:97
Software variant:
Boot loader:
7.33.1
VDSL Range A (Clean)8075.7201968.2Available----
VDSL Range B (Impacted)8070.7201960Available----
Any help and guidance would be much appreciated.
Regards
4 REPLIES 4
Message 2 of 5
Re: BT Infinity 2 Connection and speed drops.
the many drops in connection could account for the lower connection speed but your attainable speed would not be affected whereas your attainable speed and actual speed are about the same  Noise margin about normal 6db
have you tried quiet line test to see if any noise  dial 17070 option 2 should be quiet and best with corded phone
have you tried connecting to test socket with a new filter to see if that improves your connection?
cagey1two3
Message 3 of 5
Thanks for replying so fast.
I've run noise test and it has come back clear.
Very strange though since ive run the noise test and after several weeks of intermittent connections and dropped speed, my connection status has returned back to how it should be.
80.00 Mbps
20.00 Mbps
 Network uptime:
0 Days, 0 Hours 6 Minutes
 System uptime:
9 Days, 6 Hours 1 Minutes
Best regards
Message 4 of 5
great  just keep checking and post back if happens again
cagey1two3
Message 5 of 5
Will do and thanks for your help
