Message 21 of 22
Re: BT Infinity 2 Download Speeds dropped from 75mbps to 3mbps
Depends on what needs done. If they can shuffle circuits around to spread the load, then not too long. If they need to order and build more capacity, sometimes a month or a little longer. All depends.
Coverdoodle99
Message 22 of 22
Okay thank you for your help, hopefully will be resolved.
