LiamS
Message 11 of 14
Re: BT Infinity 2 Evening Slowdowns
@imjolly@pippincpThanks guys for your continue support i'll just wait it out now if they can't do nothing atleast i tried that's all i can do. Smiley Sad
Moderator
Moderator
Message 12 of 14
Hi @LiamS I called earlier and left a brief message for you. I just wanted to confirm that the cause is congestion and that BT Wholesale will move you to a less congested Svlan in the next 24hrs.
Post back and let me know how your connection is after the 24hrs has passed.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
LiamS
Message 13 of 14
@JohnC2Sorry i missed your call just listened to the voicmail and came straight here thank you for the quick response i will monitor it in the next 24hrs and see if it's sorted and keep you updated. Thank You
LiamS
Message 14 of 14
@JohnC2So did a test im getting 66mb down at off peak times and peak times getting 69mb soo still in my comfort zone will this improve once the new infrastructure is put in on 2/2/2018? It's better than what it was before though so thank you so much for getting this sorted for me.
