dean0
Message 1 of 9
BT Infinity 2 - Poor Speeds
Hello,
I have had Infinity 2 for nearly 2 years and its got to the point where I feel I am paying too much for such poor speeds.
I use hg612b modem into my own router (tested HH5 and its worse), directly connected to my desktop via CAT6 I have never seen above 25Mb Down/4Mb Up. Typical speed is around 22Mb down, checking the website my Minimum garenteed speed should be 40Mb.
I have had numerous engineers visit, they run there tests and say there is no fault and thats it.
I work for a BB compeptitor (not availible in my area), and this would not be acceptable in any way shape or form, so what the deal?
I do not want to go through the call centre from scratch to resolve this, can anyone point me in the right direction on who or how to contact.
8 REPLIES 8
Message 2 of 9
Re: BT Infinity 2 - Poor Speeds
dean0
Message 3 of 9
No, I had an engineer visit and he said there was nothing he could do, just ran a test and that was it. I have been too busy to follow this up. My stats are below if that helps diagnose:
Stats recorded 17 Oct 2015 15:12:37
DSLAM/MSAN type: BDCM:0xa459 / v0xa459
Modem/router firmware: AnnexA version - A2pv6C038m.d24j
DSL mode: VDSL2 Profile 17a
Status: Showtime
Uptime: 43 days 14 hours 44 min 3 sec
Resyncs: 0 (since 17 Oct 2015 15:08:24)
                                Downstream                             Upstream
Line attenuation (dB):      24.4                                       0.0
Connection speed (kbps): 24463                                   4424
SNR margin (dB):             6.3                                       4.7
Power (dBm):                  12.4                                     6.9
Interleave depth:               8                                          1
INP:                               46.00                                     0
G.INP: Enabled
RSCorr/RS (%):              0.0625                                  0.0519
RSUnCorr/RS (%):          0.0000                                  0.0000
ES/hour:                        0.16                                      0.59
dean0
Message 4 of 9
xdslcmd info --stats
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 1
Last initialization procedure status: 0
Max: Upstream rate = 4164 Kbps, Downstream rate = 22716 Kbps
Bearer: 0, Upstream rate = 4424 Kbps, Downstream rate = 24463 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 6.3 4.7
Attn(dB): 24.4 0.0
Pwr(dBm): 12.4 6.9
VDSL2 framing
Bearer 0
MSGc: -6 52
B: 235 127
M: 1 1
T: 0 37
R: 12 12
S: 0.3070 0.9165
L: 6462 1222
😧 8 1
I: 248 70
N: 248 140
Q: 8 0
V: 1 0
RxQueue: 20 0
TxQueue: 10 0
G.INP Framing: 18 0
G.INP lookback: 10 0
RRC bits: 0 24
Bearer 1
MSGc: 90 -6
B: 0 0
M: 2 0
T: 2 0
R: 16 0
S: 10.6667 0.0000
L: 24 0
😧 1 0
I: 32 0
N: 32 0
Q: 0 0
V: 0 0
RxQueue: 0 0
TxQueue: 0 0
G.INP Framing: 0 0
G.INP lookback: 0 0
RRC bits: 0 0
Counters
Bearer 0
OHF: 0 616212
OHFErr: 433 1130
RS: 1660969680 492377
RSCorr: 1037081 2212
RSUnCorr: 0 0
Bearer 1
OHF: 234613789 0
OHFErr: 124 0
RS: 1407682366 0
RSCorr: 11733 0
RSUnCorr: 344 0
Retransmit Counters
rtx_tx: 131881 0
rtx_c: 173179 0
rtx_uc: 21732 0
G.INP Counters
LEFTRS: 6597 0
minEFTR: 24457 0
errFreeBits: 2798422375 0
Bearer 0
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 1185223657 0
Data Cells: 2038115484 0
Drop Cells: 0
Bit Errors: 0 0
Bearer 1
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 0 0
Data Cells: 0 0
Drop Cells: 0
Bit Errors: 0 0
ES: 258 942
SES: 14 0
UAS: 290 279
AS: 3768544
Bearer 0
INP: 46.00 0.00
INPRein: 0.00 0.00
delay: 0 0
PER: 0.00 17.02
OR: 0.01 27.25
AgR: 24501.58 4451.63
Bearer 1
INP: 2.50 0.00
INPRein: 2.50 0.00
delay: 0 0
PER: 16.06 0.01
OR: 47.81 0.01
AgR: 47.81 0.01
Bitswap: 2594137/2594154 4656/4659
Total time = 1 days 7 hours 50 min 37 sec
FEC: 1449225 2516
CRC: 1195 1204
ES: 258 942
SES: 14 0
UAS: 290 279
LOS: 1 0
LOF: 8 0
LOM: 0 0
Latest 15 minutes time = 5 min 37 sec
FEC: 35 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 15 minutes time = 15 min 0 sec
FEC: 156 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 7 hours 50 min 37 sec
FEC: 5156 52
CRC: 8 19
ES: 3 19
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 1 day time = 24 hours 0 sec
FEC: 13533 88
CRC: 3 39
ES: 2 38
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Since Link time = 43 days 14 hours 49 min 3 sec
FEC: 1037081 2212
CRC: 433 1130
ES: 163 868
SES: 3 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Message 5 of 9
your stats suggest that your connection speed is about your attainable and noise margin about normal 6db so don't see where more speed will come from
enter your phone  number and post results  remember delete number  https://www.btwholesale.com/includes/adsl/main.html
are you using the test socket with a filter  especially if you have extension sockets
dean0
Message 6 of 9
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
  HighLowHighLow
FTTC Range A (Clean)69.750.92013.9--Available
FTTC Range B (Impacted)59.53519.99.6--Available
WBC ADSL 2+Up to 2--1 to 3.5Available
WBC ADSL 2+ Annex MUp to 2Up to 0.51 to 3.5Available
ADSL MaxUp to 1.5--1 to 2.5Available
WBC Fixed Rate0.5----Available
Other Offerings
FTTP on Demand33030--Available
Fibre Multicast------Available
Copper Multicast------Available
No extensions, cable straight into NTE5 MK3 with inbuit filter. I am an engineer for another BB provider, our network is very different but I know the basic stuff to look for on a ADSL/FTTC line. From what I have read online it is the distance to the fiber node causing the problem 900m estimated. An engineer previously did mention that the cables where I live are Alluminium opposed to Copper, which also does not help.
Does not seem right paying full price for a service when I am not getting the minimum guaranteed speed.
Message 7 of 9
at 900m you should still have better than you have on a normal copper line but if a lot is aluminium that could be your problem
did you actually try the test socket with a filter to rule out a problem with the MK3 - unlikley but it does happen
dean0
Message 8 of 9
Yes I have tried 2 different sockets, no difference. I don't understand why my minimum guaranted speed is much lower than what I get. Is there not a way to have a cable replaced if it is the culprit of this problem?
Message 9 of 9
Sorry in a previous post you said you had no extensions but you are saying you have tried 2 different sockets. So have you actually tried the test socket to eliminate any problems from internal wiring
if still no improvement then you need to phone customer services and get engineer visit. Openreach will only replace line as last resort especially if phone works ok
