davepa
Message 1 of 15
BT Infinity 2 Problems
I really am starting to regret joining BT
Speed tests are reporting my download tonight at around 42mb with upload around 11mb
heres my HH stats
6. Data rate:20000 / 79995
7. Maximum data rate:37084 / 128647
8. Noise margin:18.1 / 21.6
9. Line attenuation:0.0 / 8.2
10. Signal attenuation:0.0 / 8.2
The BT Wholsale speedtest is reporting 75.5 mbps speeds and 15.29 mbps with IP 77.43 AND 20.
Why is just about every other speedtest reporting speeds at around 40mbps
these tests are all wired.
14 REPLIES 14
davepa
Message 2 of 15
Re: BT Infinity 2 Problems
On the phone to BT India about as much use as a chocolate fireguard Smiley Mad
http://www.speedtest.net/result/3472360414.png
Basically been told theres no issues with my BB anything else I can help you with Sir..............mad doesn't cut it.
The day of my install I was told our external wiring was obsolete and it would be replaced to date I've never been called like I was told I would be.
davepa
Message 3 of 15
Any ideas I'm at a loss ?
Distinguished Expert
Message 4 of 15
Same problem here? https://community.bt.com/t5/BT-Infinity-Speed-Connection/Infinity-2-but-only-getting-40Mbps/m-p/1247...
To say thanks for a helpful answer, please click the white star
davepa
Message 5 of 15
Thanks for the reply really appreciate it ,
It appears my speed on the download is returning to normal however my upload is still slower.
Not sure whether this is contention or a network issue , my call to BT said possible network fault but who knows.
Message 6 of 15
So what's the speeds look like now?
davepa
Message 7 of 15
This is weird
my phone via 5ghz was giving 70mb plus but has now gone back to 43mb
heres a test wired no other internet activity
Would I be able to get a mod to look at this , I have no confidence in my phone report.
Message 8 of 15
Use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down.
http://speedtest.btwholesale.com/
This is the only test that BT will use. Make sure tht you do it wired. Also post the most recent stats from your homehub.
davepa
Message 9 of 15
1. Best Effort Test:  -provides background information.
 Download Speed
 75.13 Mbps
0 Mbps77.43 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 75.13 Mbps
 For your connection, the acceptable range of speedsis 61.95 Mbps-77.43 Mbps .
 Additional Information:
 IP Profile for your line is - 77.43 Mbps
2. Upstream Test:  -provides background information.
 Upload Speed
 12.95 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 12.95Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
davepa
Message 10 of 15
Heres my latest speedtest.net via wired
