eXploit
Message 1 of 5
BT Infinity 2 - Speed fluctuate - how long for it to stablished?
Hi
I  am on my 12th days with Infinity 2 - BT HUB 4 - but my download speed via FTP or HTTP seem to fluctuate constantly.
Windows 8 Ethernet performance chart 512mb file via HTTP
Even when testing BT Wholesale speed test ( http://www.speedtest.btwholesale.com/ ) the speed keep testing with different results. No matter if weekday or weekend , day or night. Also tested via other speed test site with a laptop - same flucturation. All are connected via Cable.
BT1
Then
Should it take this long for it to stablise ? Any suggestions?
Many Thanks
4 REPLIES 4
L7S
Message 2 of 5
Re: BT Infinity 2 - Speed fluctuate - how long for it to stablished?
I am the same issue mate...Mine tonight seems stable but the last couple of days speeds have been all over the place.
7th day now since installation.
Message 3 of 5
have you only got one device connected when carrying out the speedtest
eXploit
Message 4 of 5
Hi John46 , Nothing else connected when running the test. No other programs running , apart from background applications like antivirus.
eXploit
Message 5 of 5
For windows users - I came across this tester program which can run download test at interval http://www.gmwsoftware.co.uk/
I have just started using it and will see what results I get
