Techwizz
Message 21 of 46
Re: BT Infinity 2: Speed reduced to 40mb
LOL! @pippincp, I'm not a natural pessimist, I just don't want the OP to have false hope and I'm realistic. I just cannot see that the DLM will give a better speed than before. I am sure though that the mods will be able to increase the speed using other ways, however (fault finding).
licquorice
Message 22 of 46
ITYM @pippincp
Techwizz
Message 23 of 46
Whoops! Sorry! Edited, thanks for pointing that out. 🙂
pippincp
Sage
Message 24 of 46
I haven't given anyone false hope.
What I do know is that the mods would not have requested a DLM reset without first checking the line. Just because noise margin is at 6dB does not mean DLM hasn't taken other action and Max data rate shown by the hub isn't always correct as seen many times before.
We don't have the same access or test tools the mods have to make sweeping statements.
Techwizz
Message 25 of 46
True, hopefully I'm wrong.
CrushALL
Message 26 of 46
Ok, so I plugged my HH5 in just to see if my attainable rate had increased with the reset and it hasn't.
Clearly can see it actually has dropped which unfornate. I might be impatient since its been 2 days but if this is my real speed my line can handle now I will drop down to the 40/10 package since im getting 0% of the 80/20 yet paying more.
kickmaleerie
Message 27 of 46
I have a similar problem with my line being stable at 69/18 for 15 months and then dropping to 60/15 when nothing has been changed at my end.
I run a TP Link Archer VR900 and particiapte in SamKnows  so I have the line stats to back this up from my analytics
I also noticed that other ISPs have revised the projected Download/Upload for my line by about the same ratio on the last month: 68/18 to 59/15.
According to BT Wholesale my line should support my  previous profile. See below:
Is this the result of contention as more FTTC connections are added to the cabinet I am on?
TIA
john
imjolly
Message 28 of 46
@kickmaleerie
Your problem is a download problem whereas the post originator has a problem with connection speed  your connection speed is ok and within estimated range
CrushALL
Message 29 of 46
Ok so I got my adsl filter today so I could test my connection via the test socket.
When I undid the screws the whole faceplate came off and behind was another BT faceplate behind.
This is how it was installed when I had fibre installed and it wouldn't connect through the test socket using the fibre face plate but would using the test socket on the other faceplate.
I don't know if this is normal practise on fibre installation or could be something addding to my possible problem?
imjolly
Message 30 of 46
You need to remove the middle section as you did before you get to the test socket. This is normal
