twinkleandpop
Message 1 of 18
BT Infinity 2 and extension socket
Hi all
I have had a read through the site but cant seem to find anything that directly answers my question so I am hoping you can help!
I ordered BT Infinity 2 and was due to have it activated yesterday (7th March), I plugged the Home Hub 5 into the socket that my old router (non BT) was in and the light on the front goes to orange after it has run through the various start up cycles.  I have tried a factory reset as well as a normal push the button on the top of the hub reset as well as an unplug and leave it for a few minutes reset all resulting in the same orange light.
I had a webchat with BT earlier and they have said that I need an engineer visit and the next available one isnt until Friday 11th so will have a frustrating 4 days at least without Broadband.  Anyway, I was looking at possible problems that it could be and it struck me that the socket I have plugged the HH in to has just a plain faceplate.  The pictures that I have seen of master sockets they normally have a line accross the middle or have 2 plugs?  Our one just looks like a standard BT socket like all the others in the house.  We bought our house from new and the builders had wired the house for the phones and all phone points were in situ before BT came to connect us.
If the socket I am currently using is not the master socket would that explain the orange light on the Home Hub?  IN other words would the home hub work at all if it is plugged into an extension socket?  There is another socket in our study which could potentially be a master socket but it is behind an antique very large very heavy dresser.  I can move the dresser to check the socket but dont want to go through the hassle if my problem is not being caused by me having plugged the hub into an extension socket.
Really hope someone can let me know if plugging a home hub into an extension socket would cause the Home hub light to go to orange.
Thank you
17 REPLIES 17
Message 2 of 18
Re: BT Infinity 2 and extension socket
If the old router was working in that socket, the HH5 should also work albeit possibly not at the maximum speed possible. It sounds very much like your service has not been activated.
Message 3 of 18
Are you getting dial tone on your phone, when you plug it into the microfilter?
Message 4 of 18
infinity will worki in an extension socket depending on how your internal sockets are wired.  if wired correctly then all sockets will be conencted back to the master socket and as long as not an SSFP  like this then should work   in extension socket with filter
if you have an SSFP socket then broadband will only work in SSFP
twinkleandpop
Message 5 of 18
My old service (that was disconnected on Monday morning) was just normal broadband and not fibre, does this make a difference?  I also suspect that I have simply not been activated but I did get an email from BT at 9:30 last night to say that it had been activated and the webchat person didn't say anything about why it was not working just that I needed an engineer.  If it is just an activation issue do I need an engineer?  I really dont want to get to Friday and the engineer say that there is nothing he/she can do as it needs to be activated by BT and I have to spend the weekend broadbandless.
Both of my children are out of the country at the moment and my only contact with them is via facetime/imessages and I get little or no mobile signal at home.  Really worried about being out of contact with them for the weekend.
twinkleandpop
Message 6 of 18
Yes I get a dial tone, I used the landline this morning without a problem.
twinkleandpop
Message 7 of 18
I dont have any sockets that look like any of those pictures.  All of our sockets look like this:
http://bt.custhelp.com/rnt/rnw/img/enduser/main_socket_types_2.png
The only one I cant be sure of is the one behind the dresser in our study.  I just didnt want to go to the trouble of moving a very heavy piece of furniture to look at it if it was unlikely that my issue was the lack of master socket.
Message 8 of 18
I would put money on your service not having been activated.
Message 9 of 18
If you have a microfilter plugged into the socket, and the home hub 5 plugged into the microfilter, then it should work, unless there is a problem with the provision.
A visit will prove whether its correctly connected through the Infinity cabinet.
Message 10 of 18
if the socket behind the dresser is not where the openreach cable enter from outside that is unlikley to be a master socket.  the master is first socket where openreach cable enters your home
certainly sounds like not activated yet
