tbx1985
Message 1 of 3
BT Infinity 2 slow speeds during peak time
Looking for some help here, upgraded my old bt unlimited with bt infinity 2 at the start of the month as it had just become availiable.The speeds are between 60-70mb/s download and a steady 15mb/s upload during the day which is great although i'm at work most of that time. It slowly starts dropping from 18:30 onwards,by 20:30 its sitting between 1-4 mb/s download.After atleast 5 phone calls to bt cs my patience is starting to wear thin.It takes around 30 mins each time to get through to someone and when you do the usual response is to reset the router or they reset my line and then tell me my speeds are fine. The speeds are always ok when they call me back at 3 or 4 in the afternoon!!
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
 Download Speed
 3.51 Mbps
0 Mbps77.42 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 3.51 Mbps
 For your connection, the acceptable range of speedsis 60 Mbps-77.42 Mbps .
 Additional Information:
 IP Profile for your line is - 77.42 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 9.37 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 9.37Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
Its really poor at night and in my eyes isnt fit for purpose. They sold me this for 30 quid a month and i struggle to stream anything. If anyone can help i would be very greatful. Thanks in advance
Information for Helpdesk agents
When contacting the BT Broadband helpdesk, the agent might ask you for details about your BT Home Hub. This page contains all of the information they are likely to request
      1. Product Name: HomeHub5 2. Serial number: +076286+1521004513 3. Firmware version: v0.07.03.0814-BT (Type B) Last updated [Unknown] 4. Board version: 01 5. VDSL uptime: 1 days, 00:27:50 6. Data Rate: 20000 / 79987 7. Maximum Data Rate: 36308 / 94171 8. Noise Margin: 16.0 / 9.7 9. Line Attenuation: 0.0 / 14.4 10. Signal Attenuation: 0.0 / 0.0 11. Data sent/received: 416.6 MB / 12.5 GB 12. Broadband username: bthomehub@btbroadband.com 13. BT Wi-fi: Yes 14. 2.4GHz wireless network/SSID: BTHub5-276S
2 REPLIES 2
Sage
Sage
Message 2 of 3
Re: BT Infinity 2 slow speeds during peak time
Looks like a congestion issue which they should be aware of an hopefully rectify soon.
tbx1985
Message 3 of 3
The problem is they are not aware of it. They seem to keep fobbing me off like their isn't a problem.
