dr_wooo
Newbie
Message 1 of 3
BT Infinity 2 speed below estimate
Hi,
While I was on holiday my BT infinity 2 was activated. I have returned home to find that the wired speed is roughly 59 down and 16 up. This is less than the estimated speed I was advised.
I contacted BT via phone and got the usual "plug it into the test socket" etc but I don't see how this will make any difference when according the BT Home Hub, the max data is 59097 and 23486.
They are sending out an engineer, which I don't think I need as the speed is consistant with no drop outs or slow speeds.
Is there any way to confirm what the maximum speed has been set up for my line?
Thanks,
Russell
2 REPLIES 2
Message 2 of 3
Re: BT Infinity 2 speed below estimate
You should connect to test socket with a new filter as that may improve your coonection and increase your attainable speed there are many posts where this has helped with connection speed
Message 3 of 3
@dr_wooo wrote:
Hi,
The max data speed is a function of your line condition, if you improve your line condition by plugging into the test socket, your max data (as well as actual data) will also improve.
Speed is not 'set up' for your line, your line will achieve whatever speed it is capable of achieving.
Thanks,
Russell
