jackandrews
Message 11 of 16
Re: BT Infinity 2 speed halved
How do I call 151 if the phone doesn't work?
Message 12 of 16
phone faults
You can use the link or you cn use payphone
jackandrews
Message 13 of 16
OK, the phone line is now working and info is reporting:
6. Data rate: 14997 / 35000
7. Maximum data rate: 27289 / 75938
Is there anyway for me to request to get the DLM to re-learn?
jackandrews
Message 14 of 16
It hasn't re-learnt on its own.  Also, when I do this test
http://speedtest.btwholesale.com/
I get the following error:
"No Fibre to the Premises (FTTP) services have been found at this address. Please check the postcode or use the Telephone Number or Service ID to conduct the test.
Click here to try again."
Any ideas?
MBR123
Expert
Message 15 of 16
Yes you have to put your phone number in.
Please click on white star to the left and say thanks if I have helped you at all!. 🙂 Thank you. Some handy links Copy & Paste:-
http://bthomehub.home/
http://netalyzr.icsi.berkeley.edu/index.html
http://diagnostics.bt.com/login/?workflow=Speed
jackandrews
Message 16 of 16
Here are my results. Something is clearly wrong with my upload... any ideas?
