stuwhittaker
Message 1 of 1
BT Infinity Connection very frequently dropping - each time I see these errors...
Hi tech experts,
I had BT Infinity unlimited installed back in May and honestly not had a chance to look into sorting out the connection issues we have been having as they are very speradic!
I've not lost my patience with it and started to try a few different things.
Essentially I found this trail: https://community.bt.com/t5/BT-Infinity-Speed-Connection/PPP-LCP-Send-Termination-Request-User-reque...
and it appears I'm having the exact same issue with this warning....
What do I have?
BT Infinity Unlimited 1
MK2 filter on socket, straight into router HH5
What have I done today ? - I removed the MK2 filter and now using an old(er) ADSL filter straight into the socket and now plugged that in. Things seem stable so far - will report back.
Considering the below, what else can I do to workout what the problem may be here?
Looking at logs I see this (under WAN filter)... I notice whenever it drops... I see this match in the logs...
Recorded events
Time and date Message
14:38:44, 06 Aug.(436025.220000) WAN operating mode is VDSL
14:38:44, 06 Aug.(436025.220000) Last WAN operating mode was VDSL
14:38:43, 06 Aug.(436024.060000) PPP IPCP Receive Configuration ACK
14:38:43, 06 Aug.(436024.050000) PPP IPCP Send Configuration Request
14:38:43, 06 Aug.(436024.040000) PPP IPCP Receive Configuration NAK
14:38:43, 06 Aug.(436024.030000) PPP IPCP Send Configuration ACK
14:38:43, 06 Aug.(436024.030000) PPP IPCP Receive Configuration Request
14:38:43, 06 Aug.(436024.030000) PPP IPCP Send Configuration Request
14:38:43, 06 Aug.(436024.030000) CHAP authentication successful
14:38:42, 06 Aug.(436023.770000) CHAP Receive Challenge
14:38:42, 06 Aug.(436023.770000) Starting CHAP authentication with peer
14:38:42, 06 Aug.(436023.770000) PPP LCP Receive Configuration ACK
14:38:42, 06 Aug.(436023.750000) PPP LCP Send Configuration Request
14:38:42, 06 Aug.(436023.750000) PPP LCP Receive Configuration Reject
14:38:42, 06 Aug.(436023.750000) PPP LCP Send Configuration ACK
14:38:42, 06 Aug.(436023.750000) PPP LCP Receive Configuration Request
14:38:42, 06 Aug.(436023.740000) PPP LCP Send Configuration Request
14:36:48, 06 Aug.(435909.780000) PPP LCP Send Termination Request [User request]
14:21:20, 06 Aug.(434981.710000) WAN operating mode is VDSL
14:21:20, 06 Aug.(434981.710000) Last WAN operating mode was VDSL
14:21:19, 06 Aug.(434980.550000) PPP IPCP Receive Configuration ACK
14:21:19, 06 Aug.(434980.530000) PPP IPCP Send Configuration Request
14:21:19, 06 Aug.(434980.530000) PPP IPCP Receive Configuration NAK
14:21:19, 06 Aug.(434980.510000) PPP IPCP Send Configuration ACK
14:21:19, 06 Aug.(434980.510000) PPP IPCP Receive Configuration Request
14:21:19, 06 Aug.(434980.510000) PPP IPCP Send Configuration Request
14:21:19, 06 Aug.(434980.510000) CHAP authentication successful
14:21:19, 06 Aug.(434980.460000) CHAP Receive Challenge
14:21:19, 06 Aug.(434980.460000) Starting CHAP authentication with peer
14:21:19, 06 Aug.(434980.460000) PPP LCP Receive Configuration ACK
14:21:19, 06 Aug.(434980.440000) PPP LCP Send Configuration Request
14:21:19, 06 Aug.(434980.440000) PPP LCP Receive Configuration Reject
14:21:19, 06 Aug.(434980.430000) PPP LCP Send Configuration ACK
14:21:19, 06 Aug.(434980.420000) PPP LCP Receive Configuration Request
14:21:19, 06 Aug.(434980.420000) PPP LCP Send Configuration Request
14:21:06, 06 Aug.(434966.900000) PPP LCP Send Termination Request [User request]
