PhilG1300
Newbie
Message 1 of 5
BT Infinity Disconnecting Every Working Day During Working Hours!
Hi,
For the last week my BT Infinity has been permanently disconnected during working hours! (Weekends operating normally) Roughly 9am to 5pm. Router doesn’t connect at all through roughly these hours and then reconnects at 5pm as if nothing has happened. During the day the orange light is permanently flashing. When connected outside these hours the light is blue. I have had a home visit, unfortunately it was past 5pm by an engineer (BT subcontractor) to check, everything was fine. I have raised another fault report today and asked for an earlier appointment.
I have tried a third party router and also the Homehub 5 which was supplied with the service and both behave the same!
Any ideas?
The Timings are roughly +/- 30mins.
Regards
Phil.
4 REPLIES 4
Message 2 of 5
Re: BT Infinity Disconnecting Every Working Day During Working Hours!
Have tried using the test socket with a filter to see if that helps stability?  Have you checked that you have a dial tone and if so try quiet line test. Dial 17070 option 2 should be silent and best with corded phone
is there some in your home that switches on during the day but not at weekends
PhilG1300
Newbie
Message 3 of 5
HI,
Yes have connected to the test socket and tried new filters. Performed a Quiet Line test with a wired handswt and no crackles etc There is nothing in the house which changes at the particular hours. I suspect it is something external! As I said, I have tried a different router, filters etc, and the line does not connect. Here is an extract of the WAN log out of the modem:-
This is when it disconnects at the beginning of the day:-
08:53:54, 22 Feb.
(51758.280000) PTM over DSL is down after 0 minutes uptime
08:53:40, 22 Feb.
(51744.230000) PTM over DSL is up
08:53:09, 22 Feb.
(51712.840000) PTM over DSL is down after 0 minutes uptime
08:52:56, 22 Feb.
(51699.720000) PTM over DSL is up
08:52:24, 22 Feb.
(51667.660000) PTM over DSL is down after 491 minutes uptime
08:52:24, 22 Feb.
(51667.660000) PPPoE is down after 490 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 - Down)]
08:52:20, 22 Feb.
(51663.680000) PPP LCP Send Termination Request [User request]
This is when it connects at the end of the day:-
16:43:49, 21 Feb.
( 4448.130000) WAN operating mode is VDSL
16:43:49, 21 Feb.
( 4448.130000) Last WAN operating mode was VDSL
16:43:47, 21 Feb.
( 4446.930000) PPP IPCP Receive Configuration ACK
16:43:47, 21 Feb.
( 4446.920000) PPP IPCP Send Configuration Request
16:43:47, 21 Feb.
( 4446.910000) PPP IPCP Receive Configuration NAK
16:43:47, 21 Feb.
( 4446.910000) PPP IPCP Send Configuration ACK
16:43:47, 21 Feb.
( 4446.900000) PPP IPCP Receive Configuration Request
16:43:47, 21 Feb.
( 4446.890000) PPP IPCP Send Configuration Request
16:43:46, 21 Feb.
( 4445.990000) PPPoE is up - Down Rate=30552Kbps, Up Rate=6546Kbps; SNR Margin Down=6.1dB, Up=6.0dB
16:43:46, 21 Feb.
( 4445.980000) CHAP authentication successful
16:43:46, 21 Feb.
( 4445.790000) CHAP Receive Challenge
16:43:46, 21 Feb.
( 4445.790000) Starting CHAP authentication with peer
16:43:46, 21 Feb.
( 4445.780000) PPP LCP Receive Configuration ACK
16:43:46, 21 Feb.
( 4445.770000) PPP LCP Send Configuration Request
16:43:46, 21 Feb.
( 4445.770000) PPP LCP Receive Configuration Reject
16:43:46, 21 Feb.
( 4445.760000) PPP LCP Send Configuration ACK
16:43:46, 21 Feb.
( 4445.760000) PPP LCP Receive Configuration Request
16:43:46, 21 Feb.
( 4445.760000) PPP LCP Send Configuration Request
16:42:57, 21 Feb.
( 4396.440000) PTM over DSL is up
16:42:24, 21 Feb.
( 4363.400000) PTM over DSL is down after 0 minutes uptime
16:42:11, 21 Feb.
( 4350.500000) PTM over DSL is up
16:41:38, 21 Feb.
( 4317.450000) PTM over DSL is down after 0 minutes uptime
16:41:25, 21 Feb.
( 4304.310000) PTM over DSL is up
16:40:52, 21 Feb.
( 4271.570000) PTM over DSL is down after 0 minutes uptime
16:40:39, 21 Feb.
( 4258.480000) PTM over DSL is up
Period in between the connection is perfect!
It happens every working day for just over a week now. Perfect at weekends!
PhilG1300
Newbie
Message 4 of 5
Looks like problem has been resolved. Been informed that work has been carried out at my local exchange. Line being remotely monitored for 48hrs before fix being signed off. Broadband has held up all day with any drops. First time in 9 days.
Message 5 of 5
I guess the day time Exchange workers have stopped unplugging your line in order to plug in their heater.:smileyvery-happy:
