Andreww100
Message 1 of 2
BT Infinity - IP Profile has dropped, how do I raise/re-evaluate it?
Hi
I month ago I had some issues with my broadband connection, possibly related to the extreme bad weather we have been having. I now find that the IP Profile has dropped to 11.03 Mps (I used to be just under 35).
What process do I need to go through to get the profile re-evaluated/raised? I have re-booted both the white modem and the HomeHub 4.
 Download speedachieved during the test was - 10.69 Mbps
 For your connection, the acceptable range of speedsis 8.82 Mbps-11.03 Mbps .
 Additional Information:
 IP Profile for your line is - 11.03 Mbps
Andrew
1 REPLY 1
Sage
Sage
Message 2 of 2
Re: BT Infinity - IP Profile has dropped, how do I raise/re-evaluate it?
You need an engineer out to test the line and reset your IP Profile. Call CS.
