Moderator
Moderator
Message 21 of 23
Re: BT Infinity Multiple drop outs (daily)
Hi @jandjwilliman,
If you send me in your details I'll be able to arrange an engineer if needed. You can send me in your details using the "Contact The Mods" link found in my profile.
PaddyB
Message 22 of 23
@jandjwilliman
How is that for service Smiley Wink
You will need to view this forum on the full site view, and not the mobile view, to be able to see the contact link.
Contact @PaddyB and leave it to the team, no need to contact customer services.
Moderator
Moderator
Message 23 of 23
Hi @jandjwilliman Thanks for taking my call earlier and confirming the fault has been fixed.
The engineer found an external fault of corrosion and repaired the connection.
cheers
John
