Autograph
Message 1 of 12
BT Infinity - Phone rings internet disconnects
So, had my BT Infinity Option 1 Installed today. Everytime, my house phone rings (landline) my internet disconnects, and this happens straight after the phone finishes too. I have never had this problem I have everything setup properly, filters on phonelines vice versa. Clean setup. Anyways, just need help on how to fix this.  Not really desperate or anything, because I have an engineer booked to visit me this week Friday.
11 REPLIES 11
Message 2 of 12
Re: BT Infinity - Phone rings internet disconnects
If you connect to test socket does broadband still drop on receiving a call?
Autograph
Message 3 of 12
I shall test this out tomorrow and let you know what happens. Just for additional information, I have FTTC so I had to setup my router.
Message 4 of 12
did you get an engineer to install your fibre with new filtered master socket or did you self install with standard filters?
Autograph
Message 5 of 12
It was self installed. Also tested as well when I test on the test socket that it still disconnects when the phone rings.
Distinguished Guru
Message 6 of 12
The phone should be disconnected by using the test socket
If not, I'll try again 🙂
Autograph
Message 7 of 12
Still getting disconnected.
Autograph
Message 8 of 12
Looking at the event logs on the BT HH5. Looks weird. This is what happens when someone phones my house
18:02:46, 05 Jun.BLOCKED 2 more packets (because of Advanced Filter Rule)
18:02:45, 05 Jun.OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath12_out/rule/0: UDP 0.0.0.0:68->255.255.255.255:67 on ath12)
18:02:42, 05 Jun.ath00: STA 40:f3:08:41:4e:89 IEEE 802.11: Client disassociated
18:02:42, 05 Jun.ath00: STA 40:f3:08:41:4e:89 IEEE 802.11: Client associated
18:02:38, 05 Jun.OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.98:1831->31.55.162.215:443 on ppp3)
18:02:32, 05 Jun.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.100:61787->23.198.96.34:443 on ppp3)
18:02:30, 05 Jun.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.100:61791->23.198.65.164:443 on ppp3)
18:02:30, 05 Jun.(96770.600000) Port forwarding rule added via UPnP/TR064. Protocol: UDP, external ports: any->3658, internal ports: 3658, internal client: 192.168.1.100
18:02:29, 05 Jun.ath00: STA fc:0f:e6:4e:12:4a IEEE 802.11: Client associated
18:02:29, 05 Jun.ath00: STA fc:0f:e6:4e:12:4a IEEE 802.11: Client disassociated
18:02:28, 05 Jun.IN: ACCEPT [57] Connection closed (Port Forwarding: TCP 192.168.1.100:48154 <-->86.132.149.47:48154 [66.193.112.93:443] CLOSED/CLOSED ppp3 Route)
18:02:28, 05 Jun.BLOCKED 2 more packets (because of Advanced Filter Rule)
18:02:28, 05 Jun.(96768.770000) CWMP: session completed successfully
18:02:28, 05 Jun.(96768.520000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
18:02:28, 05 Jun.(96768.110000) Host android-c43c4e4a06ebe8bb (MAC cc:3a:61:e8:ea:c1) using IP 192.168.1.99 detected on interface ath10, port -1
18:02:28, 05 Jun.ath00: STA 40:f3:08:41:4e:89 IEEE 802.11: Client disassociated
18:02:27, 05 Jun.OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath12_out/rule/0: UDP 0.0.0.0:68->255.255.255.255:67 on ath12)
18:02:25, 05 Jun.(96765.330000) OpenWiFi IPSec connection is up
18:02:25, 05 Jun.ath00: STA 40:f3:08:41:4e:89 IEEE 802.11: Client associated
18:02:23, 05 Jun.IN: ACCEPT [57] Connection closed (Port Forwarding: TCP 192.168.1.100:1913 <-->86.132.149.47:1913 [66.235.139.206:443] CLOSED/CLOSED ppp3 Route)
18:02:23, 05 Jun.ath00: STA fc:0f:e6:4e:12:4a IEEE 802.11: Client associated
18:02:23, 05 Jun.ath00: STA fc:0f:e6:4e:12:4a IEEE 802.11: Client disassociated
18:02:23, 05 Jun.ath00: STA 40:f3:08:41:4e:89 IEEE 802.11: Client disassociated
18:02:23, 05 Jun.ath00: STA 40:f3:08:41:4e:89 IEEE 802.11: Client associated
18:02:23, 05 Jun.ath00: STA cc:3a:61:e8:ea:c1 IEEE 802.11: Client disassociated
18:02:23, 05 Jun.ath00: STA cc:3a:61:e8:ea:c1 IEEE 802.11: Client associated
18:02:22, 05 Jun.IN: ACCEPT [57] Connection closed (Port Forwarding: TCP 192.168.1.100:1915 <-->86.132.149.47:1915 [66.235.139.206:443] CLOSED/CLOSED ppp3 Route)
18:02:22, 05 Jun.ath00: STA cc:3a:61:e8:ea:c1 IEEE 802.11: Client disassociated
18:02:20, 05 Jun.OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_br1_out/rule/1: ICMP type 8 code 0 10.174.228.153->10.174.228.154 on br1)
18:02:20, 05 Jun.BLOCKED 2 more packets (because of Advanced Filter Rule)
18:02:19, 05 Jun.OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath12_out/rule/0: UDP 0.0.0.0:68->255.255.255.255:67 on ath12)
18:02:18, 05 Jun.BLOCKED 2 more packets (because of Advanced Filter Rule)
18:02:18, 05 Jun.ath00: STA fc:0f:e6:4e:12:4a IEEE 802.11: Client disassociated
18:02:17, 05 Jun.ath00: STA 40:f3:08:41:4e:89 IEEE 802.11: Client disassociated
18:02:16, 05 Jun.OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath12_out/rule/0: UDP 0.0.0.0:68->255.255.255.255:67 on ath12)
18:02:16, 05 Jun.ath10: STA cc:3a:61:e8:ea:c1 IEEE 802.11: Client associated
18:02:12, 05 Jun.(96752.610000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
18:02:12, 05 Jun.(96752.610000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
18:02:12, 05 Jun.(96752.700000) Device disconnected: Hostname: android-2112e607a148f7c7 IP: 192.168.1.65 MAC: 40:f3:08:41:4e:89
18:02:12, 05 Jun.ath00: STA 40:f3:08:41:4e:89 IEEE 802.11: Client associated
18:02:02, 05 Jun.(96742.710000) WAN operating mode is VDSL
18:02:02, 05 Jun.(96742.710000) Last WAN operating mode was VDSL
18:02:01, 05 Jun.(96741.410000) PPP IPCP Receive Configuration ACK
18:02:01, 05 Jun.(96741.410000) PPP IPCP Send Configuration Request
18:02:01, 05 Jun.(96741.400000) PPP IPCP Receive Configuration NAK
18:02:01, 05 Jun.(96741.400000) PPP IPCP Send Configuration ACK
18:02:01, 05 Jun.(96741.400000) PPP IPCP Receive Configuration Request
18:02:01, 05 Jun.(96741.400000) PPP IPCP Send Configuration Request
18:02:01, 05 Jun.(96741.400000) CHAP authentication successful
18:02:01, 05 Jun.(96741.290000) CHAP Receive Challenge
18:02:01, 05 Jun.(96741.290000) Starting CHAP authentication with peer
18:02:01, 05 Jun.(96741.290000) PPP LCP Receive Configuration ACK
18:02:01, 05 Jun.(96741.290000) PPP LCP Send Configuration Request
18:02:01, 05 Jun.(96741.290000) PPP LCP Receive Configuration Reject
18:02:01, 05 Jun.(96741.280000) PPP LCP Send Configuration ACK
18:02:01, 05 Jun.(96741.280000) PPP LCP Receive Configuration Request
18:02:01, 05 Jun.(96741.280000) PPP LCP Send Configuration Request
Distinguished Guru
Message 9 of 12
You probably have a line fault. You will need an engineer to come and fix it.
Autograph
Message 10 of 12
Hopefully, I have an engineer coming tomorrow.
