Gazza02
Message 1 of 16
BT Infinity Problems For The Last 11 Days
Starting my own thread now since these problems have been going on for over 10 days. I have been previously posting in this thread https://community.bt.com/t5/BT-Infinity-Speed-Connection/BT-Infinity-issues-for-the-last-few-days/td...
Now the problems are still here where webpages refuse to load and if they do load images are missing or they look like the images I have previously posted.
Ray said last night that this could be a congestion issue so I would really like one of the mods to get involved to check my connection to see what is going on since it was perfectly fine 2 weeks ago. As I said all speed tests come back OK that is where its weird my speed is never dropping.
I would rather go back onto broadband since I could load webpages fine its a bit silly that I am on infinity and cant even do that.......
15 REPLIES 15
Gazza02
Message 2 of 16
Re: BT Infinity Problems For The Last 11 Days
Here are the images to the amount of packetloss I have been getting:
Then last night:
Can A mod please help?
Message 3 of 16
if congestioon is there anything here for your exchange  http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
http://bt.custhelp.com/app/answers/detail/a_id/15036
http://community.plus.net/exchange-information/
Gazza02
Message 4 of 16
I am on the Kensal Green exchange it doesnt say anywhere that there are problems with capacity. Thats why I would like this investigated
Gazza02
Message 5 of 16
Right now the internet is near enough unusable these forums take 20 or more seconds to load and most websites load up like
Gazza02
Message 6 of 16
I dont understand why no mods want to get involve and help with this issue its been going on for soo long now and doesnt seem like it is improving at all, it just seems like it is getting worse...........
Distinguished Guru
Message 7 of 16
Have you tried changing your DNS to use Google?
If not, I'll try again 🙂
Moderator
Moderator
Message 8 of 16
Hi Gazza02,
Please use the 'contact the mods' link in my forum profile to send in your details and we'll run some checks on your connection. You can find the link by clicking on my username.
Neil
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Gazza02
Message 9 of 16
Yep tried changing to Google and Open DNS no change at all, I have tested it on my wired PC and my wireless laptop that I also connected up with an ethernet cable 😞
Gazza02
Message 10 of 16
Thanks Neil I have contacted you with the details, hopefully you can help me get this sorted 🙂
