tg92
Message 1 of 7
BT Infinity Profile stuck since 2011
Hello, I recently obtained some detailed stats after all these years of being on BT Infinity. Can anyone tell me if they're bad/good and if I have any chance of getting a faster connection? I've been stuck at 45Mb for seven years...
I'm on BT Superfast Fibre Plus (The lowest tier, I think?)
BT Checker using my telephone:
VDSL Range A - 66 - 45.3 | 17.2 - 11 | Threshold - 39.8
VDSL Range B - 55.2 - 35 | 14.6 - 7.8 | Threshold - 31.1
Here's all the stats I obtained when I unlocked the openreach modem
Line profile
Download 44534 | Upload 9926
Attainable Rate
Download 43320 | Upload - 9926
VDSL 17A
Line Attenuation
Download 18.6 | Upload 0.0
SNR Margin
Download 6.1 | Upload 6.2
Power(?)
14.0 | 7.4
INP
Download 47.00 | Upload 0
G.INP
Download Enabled | Upload Not Enabled
Vectoring Status (?) 5
SNR Margin 18.6
Line Attentuation 14
6 REPLIES 6
Message 2 of 7
Re: BT Infinity Profile stuck since 2011
45mb is right at bottom of your estimated range are you using the test socket with a new filter to see if that gives you a bit more speed?
tg92
Message 3 of 7
I tested it with the standard infinity faceplate. Should I take the faceplate off and use the test socket?
Message 4 of 7
your best conenction is with a filter in the test socket as that eliminates evrything else  you may find not much difference but al least you have checked   also initially maybe not much faster connection speed but also check if attainable has increased
tg92
Message 5 of 7
Update: I re-flashed my modem with the 08 firmware, I mistakenly used the old 06 firmware pre G.INP. I don't know if this is the cause for my new speeds but in the last 24 hours my speed has increased by 8Mb.
I ran the bt speedtester and my IP Profile is capped at 46Mb, do I need to wait for my profile to automatically change or will resetting the router/modem activate the new speeds? I don't want to turn off the equipment whilst DLM is actually helping me out. I just don't know why my IP Profile hasn't adjusted for the speed increase 😕
My stats via telnet:
xdslcmd info --stats
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason:	1
Last initialization procedure status:	0
Max:	Upstream rate = 9773 Kbps, Downstream rate = 52396 Kbps
Bearer:	0, Upstream rate = 9773 Kbps, Downstream rate = 53073 Kbps
Bearer:	1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Link Power State:	L0
Mode:			VDSL2 Annex B
VDSL2 Profile:		Profile 17a
TPS-TC:			PTM Mode(0x0)
Trellis:		U:ON /D:ON
Line Status:		No Defect
Training Status:	Showtime
		Down		Up
SNR (dB):	 3.2		 6.2
Attn(dB):	 18.6		 0.0
Pwr(dBm):	 13.9		 7.4
			VDSL2 framing
			Bearer 0
MSGc:		-6		26
B:		227		237
M:		1		1
T:		0		34
R:		12		16
S:		0.1366		0.7732
L:		14052		2628
D:		4		1
I:		240		127
N:		240		254
Q:		4		0
V:		0		0
RxQueue:		128		0
TxQueue:		32		0
G.INP Framing:		18		0
G.INP lookback:		31		0
RRC bits:		0		24
			Bearer 1
MSGc:		122		-6
B:		0		0
M:		2		0
T:		2		0
R:		16		0
S:		8.0000		0.0000
L:		32		0
D:		1		0
I:		32		0
N:		32		0
Q:		0		0
V:		0		0
RxQueue:		0		0
TxQueue:		0		0
G.INP Framing:		0		0
G.INP lookback:		0		0
RRC bits:		0		0
			Counters
			Bearer 0
OHF:		0		914894
OHFErr:		0		0
RS:		175287312		1030882
RSCorr:		17256		0
RSUnCorr:	0		0
			Bearer 1
OHF:		374287		0
OHFErr:		0		0
RS:		2993805		0
RSCorr:		8		0
RSUnCorr:	0		0
			Retransmit Counters
rtx_tx:		294848		0
rtx_c:		721		0
rtx_uc:		69054		0
			G.INP Counters
LEFTRS:		11		0
minEFTR:	53074		0
errFreeBits:	98734791		0
			Bearer 0
HEC:		0		0
OCD:		0		0
LCD:		0		0
Total Cells:	613579831		0
Data Cells:	23955756		0
Drop Cells:	0
Bit Errors:	0		0
			Bearer 1
HEC:		0		0
OCD:		0		0
LCD:		0		0
Total Cells:	0		0
Data Cells:	0		0
Drop Cells:	0
Bit Errors:	0		0
ES:		11		24
SES:		11		0
UAS:		58		47
AS:		6013
			Bearer 0
INP:		51.00		0.00
INPRein:	1.00		0.00
delay:		0		0
PER:		0.00		6.59
OR:		0.01		38.79
AgR:		53189.82	9811.50
			Bearer 1
INP:		2.00		0.00
INPRein:	2.00		0.00
delay:		0		0
PER:		16.06		0.01
OR:		63.75		0.01
AgR:		63.75	0.01
Bitswap:	2136/2137		33/33
Total time = 18 hours 50 min 26 sec
FEC:		33033		59
CRC:		591		23
ES:		11		24
SES:		11		0
UAS:		58		47
LOS:		1		0
LOF:		10		0
LOM:		0		0
Latest 15 minutes time = 5 min 26 sec
FEC:		447		0
CRC:		0		0
ES:		0		0
SES:		0		0
UAS:		0		0
LOS:		0		0
LOF:		0		0
LOM:		0		0
Previous 15 minutes time = 15 min 0 sec
FEC:		1039		0
CRC:		0		0
ES:		0		0
SES:		0		0
UAS:		0		0
LOS:		0		0
LOF:		0		0
LOM:		0		0
Latest 1 day time = 18 hours 50 min 26 sec
FEC:		33033		59
CRC:		591		23
ES:		11		24
SES:		11		0
UAS:		58		47
LOS:		1		0
LOF:		10		0
LOM:		0		0
Previous 1 day time = 0 sec
FEC:		0		0
CRC:		0		0
ES:		0		0
SES:		0		0
UAS:		0		0
LOS:		0		0
LOF:		0		0
LOM:		0		0
Since Link time = 1 hours 40 min 11 sec
FEC:		17256		0
CRC:		0		0
ES:		0		0
SES:		0		0
UAS:		0		0
LOS:		0		0
LOF:		0		0
LOM:		0		0
Sage
Sage
Message 6 of 7
Looking at your current stats it would appear you are at the max your line can support
Message 7 of 7
from stats looks like G.INP is active and I agree with @pippincp you are now as good as it gets  your profile is based on connection speed not other way round and speed is at max
