NickChurch
Message 11 of 17
Re: BT Infinity Speed dropping to very slow bitrates in the evening
I was using the full version of the site - I see now that a contact the mods link has now appeared. So I will do that
NickChurch
Message 12 of 17
I have completed the form. I hope this is the start of the situation being resolved.
Moderator
Moderator
Message 13 of 17
Thanks for confirming that @NickChurch, sorry for any confusion.
We're busier than usual so it's taking longer than expected to reply but once you've submitted the details we'll get to you in turn.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
Sage
Sage
Message 14 of 17
@NickChurch wrote:
Oh my god - this  is so frustrating!!!
 3 Engineers have now planned to come. I have taken days off work, they have all cancelled because they do a line check and it's fine. However I've tried to tell them that it's always fine during the day, it's the evening thats the problem. But they cannot seem to understand this.
The fact is the engineers are correct. Your problem is not one Openreach engineers can resolve. Wiat for the mods to get back to you and you will only deal with them until resolved.
NickChurch
Message 15 of 17
 9/10/2016
We have hit a new low tonight - 1.5mbps. And earlier this evening, it was only 750k. I hope this Infinity is sorted soon. I only bought in as the broadband in our area was only 3mbps. That seems like luxury now 😞
Look forward to hearing from someone
NickChurch
Message 16 of 17
Just an update that this is no better. I have had 4 engineers out and it's still the same. What next?
Message 17 of 17
Engineers will never be able to resolve this.
It's a peak time congestion issue which will only be resolved once BT wholesale increase capacity in the backhaul, or spread the load across some lighter utilised Virtual Pathways.
