VideoFletcher
Message 1 of 4
BT Infinity ( When / If ) will I be able to get it?
Im from Blackpool, North West, well Thornton to be specific and already Fleetwood and other areas are getting it, on the image of future places Blackpool / Thornton isn't on the list even though thousands want it and its literally a mile away from places that already have it.
When I check my Phone Number /Line it says I can get it on september but this doesnt match with this image/
http://www.fibremap.bt.com/
Is the image wrong or is the line checker wrong?
Thanks and come to blackpool / Thornton. Im sick of 1 meg down and 0.1 UP.
3 REPLIES 3
Guru
Message 2 of 4
Re: BT Infinity ( When / If ) will I be able to get it?
Hi, in my honest opinion I would stick with the checker as this has overall been more valuable and reliable about what services are available to you.
The image or fibre map may have not been updated as of yet.
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
Busa
Message 3 of 4
Hi i live in Cleveleys so very close to you, i think you will find you are on the cleveleys exchange which is due to be upgraded by the end of September.
Kev
VideoFletcher
Message 4 of 4
I have it now, 50 meg down and 15 up. Feels so nice after 1meg down and 0.2 up.
