JackHammer20
Message 21 of 32
Re: BT Infinity and gaming ping????
lambo7
Message 22 of 32
It's on both wired and wireless. But I notice it more on wireless as my gaming PC is wireless. I'll also check these new links out. I'm paying a lot for infinity and if I can't play games I won't be happy 😞
Distinguished Guru
Message 23 of 32
If your problem is with gaming over wireless, the best fix is to use wired ethernet.
Other wise you're in the realm of wifi problems, caused by interference from neighbours, and smart wireless automatically switching channels which means your PC get disconnected and has to reconnect - to mention just 2 of the many wireless problems.
If not, I'll try again 🙂
lambo7
Message 24 of 32
It's been great for 4 years. It's only been playing up the last 2 ish months. I've got NO new tech so I can't believe it's an interference problem as it was ok before?????
Distinguished Guru
Message 25 of 32
Are you connecting on 2.4GHz or 5GHz?
lambo7
Message 26 of 32
Not a clue. How do I check? And when I'm looking which is the best one and I'll change it if needed. Thanks.
Distinguished Guru
Message 27 of 32
Best think to do then is to go into your advanced settings on the HH5 and select the wireless tab.
Then select the 5GHz tab and select NO to "Sync with 2.4 GHz:".
Then choose a new SSID by adding "5" to the existing one, so you can tell the difference between 2.4GHz and 5GHz networks.
While you're there change "Channel selection:" from "Smart wireless" to the current channel.
Then press the "Apply" button.
Then choose the 2.4GHz tab and change "Channel selection:" from "Smart wireless" to the current channel on 2.4GHz.
Then press the "Apply" button again.
Now on your PC you can select which band to connect to.
Tags (2)
lambo7
Message 28 of 32
Ok. Thanks. I'll try this soon.
lambo7
Message 29 of 32
Ok. It's done. Tried a few speed tests and the 5ghz ping is 1ms quicker. I'll try both on some games tomorrow. Thanks for help. Sorry to be a pain.
-AndyH-
Expert
Message 30 of 32
Which game/s are you having problems with?
