lambo7
Message 11 of 32
Re: BT Infinity and gaming ping????
Just googled FTTP. As far as I know as its a new house I have fibre to my house and normal phone wire in the house.
lambo7
Message 12 of 32
As far as I'm aware. I have fibre to my house, phone wires to the master socket, modem then home hub. ?
Distinguished Guru
Message 13 of 32
So why do you have a modem? The HH5 doesn't need a modem.
If not, I'll try again 🙂
lambo7
Message 14 of 32
Ok. I'll try to plug the wire to the modem directly into the homehub?? What socket? WAN or DSL ? Thanks.
Distinguished Guru
Message 15 of 32
DSL
lambo7
Message 16 of 32
thanks, its working direct from master socket. i'll try a game or two later and see IF its any better???? thanks for the help.
steve
Distinguished Guru
Message 17 of 32
You can now post your line stats, if you don't mind 😉
These are in Troubleshooting/Helpdesk on the web interface at http://192.168.1.254
Lines 1-13 will be enough
lambo7
Message 18 of 32
Ok. I'll do it in next 30mins.
lambo7
Message 19 of 32
1. Product Name: HomeHub52. Serial number: +076284+14310001423. Firmware version: v0.07.03.0814-BT (Type B) Last updated 3/12/20144. Board version: 015. VDSL uptime: 0 days, 01:15:456. Data Rate: 19999 / 704217. Maximum Data Rate: 26181 / 846618. Noise Margin: 15.1 / 6.39. Line Attenuation: 0.0 / 14.010. Signal Attenuation: 0.0 / 0.011. Data sent/received: 44.0 MB / 193.0 MB12. Broadband username: bthomehub@btbroadband.com13. BT Wi-fi: Yes
Distinguished Guru
Message 20 of 32
Your data rate of 70 Mbps is in line with the attenuation of 14, so I don't think there's a problem there.
Are you actually having problems over wifi not wired ethernet?
