Message 1 of 14
BT Infinity and video buffering ?
Just wondering why it is that any video we try and watch on the internet plays for a few minutes and then buffers. The Infinity speed is a constant 37.48Mbps down so should be adaquate. I've changed the BT hub for a Draytek Vigor router in an effort to resolve this issue but it still happens.
Something I have noticed is that the Draytek router doesn't reboot every week like the BT Hub did. Every Friday at 12.00noon it would reboot. BT just ignored my requests for a explaination.
This buffering is driving me bonkers - it shouldn't happen when I'm paying BT all the time for a service.
Any suggestions to fix it would be appreciated.
13 REPLIES 13
Message 2 of 14
Re: BT Infinity and video buffering ?
Are you connecting by Ethernet or wireless. For the best results you should use Ethernet. Wireless can be prone to interference.
Message 3 of 14
Thanks for the response.
I've yet to find a way of connecting an Ipad with a cable. The issue is also happening when connected via a cable to PC. I really did think it was to do with the BT router but obviously not with the Draytek giving the same result.
I'll keep hunting for a solution.
Message 4 of 14
run btspeedtester with your pc connected by ethernet (no powerline adapter) and when first test completes then run diagnostic test and post results http://speedtest.btwholesale.com/
Sage
Message 5 of 14
You need a USB to Ethernet adapter such as the one below.
£4.99 from a well known auction site.
Message 6 of 14
Thanks anyway but there is no USB socket on an ipad.
Message 7 of 14
FAQ
Results Image not loaded
1. Best Effort Test:
Download Speed : 37.28 Mbps
2. Upstream Test:
Upload Speed : 6.55 Mbps
Message 8 of 14
that is result from first test but can you continue and run second test which is diagnostic and post results  again with ethernet
Sage
Message 9 of 14
Is there a mini/micro USB as there are variants for  that.
Message 10 of 14
The only connection is for the Apple lightening connector.
