I knew your phone number wouldn't work, that's why I said enter your address.
Openreach Engineers shouldn’t drill through UPVC door/window frames.
They’re only supposed to drill through walls and wooden frames.
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability Date High Low High Low Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability DateFTTP Install ProcessADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date Observed SpeedsVDSLOther Offerings Availability Date
Our records show the following FTTP network service information for these premises:- Single Dwelling Unit Residential OH Feed with no anticipated issues.
FTTP is available and a new ONT may be ordered.
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage. This line is on a Market B Exchange. For VDSL or G.fast Ranges A and B, the term "Clean" relates to a line which is free from any wiring issues (e.g. Bridge Taps) and/or Copper line conditions, and the term "Impacted" relates to a line which may have wiring issues (e.g. Bridge Taps) and/or Copper line conditions.
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
Throughput/download speeds will be less than line rates and can be affected by a number of factors within and external to BT's network, Communication Providers' networks and within customer premises. The Stop Sale date for Datastream is from 30-Jun-2012; the Formal Retirement date for Datastream is from 30-Jun-2014. The Stop Sale date for IPstream is from 31-Dec-2012; the Formal Retirement date for IPstream is from 30-Jun-2014. Please note that postcode and address check results are indicative only. Most accurate results can be obtained from a telephone number, NAD, UPRN or Access Line ID (ALID) check.Note: If you decide to place an order for a WBC fibre product, an appointment may be required for an engineer to visit the end user's premises to supply the service.
Thank you for your interest. |
Hello,
Thanks for you help trying to help me find out. I have posted the information provided by the page.
Regards,
Peternac26
You will be getting FTTP so some drilling will be necessary. There will be a wall mounted ONT with battery back-up fitted in your home so consider where you want it to be before the engineer arrives.
Thanks for your help. I currently get the internet with Talk Talk through the BT line master socket and it works very well the internet - netflix, etc . Is there any benefit of moving to the new system with BT ?
There are plenty of benefits of moving to FTTP. No possibility of crosstalk slowing your internet down, speeds up to 330Mbps and higher in the future. Pure fibre is the best available connection.
It's interesting that your property has been enabled for FTTP given that it already has reasonable FTTC (50/10) speeds available. Moving from FTTC 50/10 to FTTP 50/10 will give you a slightly faster download speed and lower latency so websites may load slightly quicker but you will only really benefit by moving to the more expensive FTTP packages which offer much higher download and upload speeds.
My FTTP installation used newer connectorised fibre cable which went straight through the outside wall - there is no outside box. Bear in mind that you will have two boxes - an ONT (which is the optical modem) and a BT HomeHub which connects to the ONT so you will require two power sockets where the cable comes in. The fibre cable can be run to a different place to your current master socket so you may wish to have it installed in a different room.
Thanks very much for you explanation !!
FTTP is a no-brainer, you are getting a Rolls Royce at Ford prices.
