kenthom2
Message 1 of 7
BT Infinity compatability issues
Hi, I have a BT Infiniti service FTTC running into my office and BTHUB6, I then beam the signal using a pair of Ubiquiti airMAX dishes to a satellite office 500 metres awaywith the signal running through a wifi router, to provide a broadband service at that satellite office. The Ubiquiti dishes beam the service at 100% efficiency but there's a problem, connecting devices at  either office is completely hit or miss. Often either with wifi or ethernet, connections register as 'no internet available'. Its infuriating and I've thought it was a IPV6 vs IPV4 issue, but the HUB6 transmiits over both and connected laptops network cards are compatible with both, still no connection - sometimes.
Is the intermittent nature of the problem indicative of a HUB6 fault or incoming signal fault? Can someone please advise how to best diagnose the problem
6 REPLIES 6
pippincp
Message 2 of 7
Re: BT Infinity compatability issues
A good start would be to post the hub connection stats. see HERE if you don't know how.
imjolly
Message 3 of 7
are you a business user?
kenthom2
Message 4 of 7
Yes, a business user...
Keith_Beddoe
Message 5 of 7
This is the BT Residential Customers forum
As you are a business user, please could you post on the BT Business forum at http://business.forums.bt.com/
Someone there may be able to advise, or offer an alternative business solution, or possibly a different BT product to connect to your network.
kenthom2
Message 6 of 7
Thanks, sorry I didnt know there was a different forum...
Keith_Beddoe
Message 7 of 7
Its not a problem, its just that some of the configurations are different, like static IP addresses. Also not sure of the IPv6 status on business connections.
The business forum is not as busy as this one, but there are a couple of BT Employees (moderators) who do try to help.
Mostly its customer customer support, like this forum.
