CM90172
Newbie
Message 1 of 2
BT Infinity has slow down a lot recently.
I used to be able to get download speeds of around 10mb/s and now it bearly reaches 3mb/s.
I have also tried the speed test.
1 REPLY 1
Message 2 of 2
Re: BT Infinity has slow down a lot recently.
Wired or wireless?
What are you downloading and where from?
How many devices connected to the home hub?
Can you run the further diganostics test at http://speedtest.btwholesale.com with an Ethernet connection and post up the results please along with answers to the above questions 🙂
