jb1924
Message 1 of 4
BT Infinity installation cost
I live in a three storey flat (2nd Floor) where the main BT installation is on the ground floor I am advised that I can receive Infinity  What, if any, is the likely cost of getting infinity into my flat, and how do I get BT to agree this before placing an order John P
3 REPLIES 3
JohnTee
Message 2 of 4
Re: BT Infinity installation cost
Just phone BT and explain the situation to them. They will give you all info regarding cost etc - if any.
conrad
Recognised Expert
Message 3 of 4
The installation will be straight forward as the existing master socket will be used (assuming you have a landline connected) - the thing to watch out for is that you need 2 power sockets one each for Modem and Router which may be a pain if the master is in a bedroom (like mine) -it can be moved by the engineer doing the installation at no cost.
Any costs will be as per the pricing on the website.
Message 4 of 4
as you have an existing line there will be no additional charges for an infinity install
