razinyorks
Newbie
Message 51 of 712
Re: BT Infinity issues for the last few days
Just want to add my voice on this too - same problem here in West Yorkshire for the last few days. As others have said only seems to be web traffic effected. Some kind of packet filtering going wrong perhaps?
leigh_73
Message 52 of 712
Same issue here in Surrey, started monday lunchtime. Spent 30 minutes on the phone to BT's international call centre last night going through various tests (which i had already done myself) effectively my download / upload speeds are fine, ping is high (25-35ms) and most web pages are incredibly slow to load. BTs solution was to send an engineer to my house which i would potentially be charged for. I told them not to bother as it wasnt a local issue, more national and pointed them to this thread. Not that it will help.
Also my BT TV youview service wont play on demand services either now with this issue
Ironically i couldnt log into here at home to post my problem.
psykix
Message 53 of 712
Just to add my +1 to this.
Traceroute fails at 2nd and 3rd hops - there appears to be some sort of routing issue in the BT network.
I'm currently on to BT but as others have said they are reluctant to investigate due to me using an Asus router!
I've also lost my Youview extra channels with an IPC6023 error.
jezthomp
Message 54 of 712
Is this happening to all BT cusomers or just random ones?
What have they done, all i get is speed and ping okay so they cannot do anything.
Its a shambles!
psykix
Message 55 of 712
Just to add.. speedtest is fine. Also BT Sport via the iPad app works fine, but not on the Youview boxes.
Most odd..
I've also referred them to this thread.
leigh_73
Message 56 of 712
Had the same response jexthomp, speedtest and ping are within acceptable limits so its not our problem. sorry, monitor it for a few days and it should be fine
MrBelter
Expert
Message 57 of 712
I am also having problems in Yorkshire
Speedtest shows speeds fine (this is over a wireless connection) http://www.speedtest.net/result/3976430379.png
PS3 unusable, getting signed in and out of the PSN, cant download updates, can't use Netflix.
PS4 unusable, getting signed in and out of the PSN, cant download updates, can't use Netflix.
Many sites really slow to load or don't load until a refresh.
Rebooted my HH5a a number of times, reset Homeplugs, changed PS3 and PS4 to wireless then back to wired, checked ports, DMZ etc. used different Ethernet cables, tried my old fibre modem and HH3.
Its not me BT, it's you Smiley Happy
anthonyUK
Expert
Message 58 of 712
@Stuartd wrote:
... I have tried everything under the sun to try and fix this issue.
Try using a VPN and see if it still occurs Smiley Wink
There are a number of free ones you can try to test.
Also make a note of a well known servers IP address when it works e.g. ping www.bbc.co.uk
Use this in IP in a browser rather than the name.
I know it won't solve your issue but it will highlight where the issue is.
psykix
Message 59 of 712
It doesn't appear to be a DNS issue, so using the IP address doesn't make any difference - at least not from what I'm experiencing.
EvilShubunkin
Message 60 of 712
Getting similar problems - Netflix gave an error on first attempt today, then did load up after a longer than usual wait.  This is on a Sony TV but once logged in streaming was OK.
Replying to a post on another forum, clicking on Reply caused a "Page cannot be displayed" error briefly before slowly loading the page.  10 - 15 seconds slowly when normally it would be instant.
Happening for a couple of days now, did think something was up when CoD (on PC) wasn't connecting two times out of three.
