Techwizz
Message 11 of 19
Re: BT Infinity just dropped speed
Well, it appears that your downstream rate is banded at 67 Mb due to all the disconnections. Your line is capable of a downstream rate of 80 Mb at a SNRM of 6 dB. So, if there's no noise on the line, you need to request a DLM reset, which I'm sure a mod will be able to approve.
Chromedome73
Message 12 of 19
Thanks, how would I request that or will they pick up on this thread ?
Message 13 of 19
The normal course of action will be that if your line has stabilised and there are no disconnects DLM will gradually raise your speed.
Moderators will normally only become involved if after a few weeks DLM has not done its job and in that case it could be indicative of a fault on the line.
Techwizz
Message 14 of 19
Hopefully, they will pick it up.
Techwizz
Message 15 of 19
Hmm, partly true. It has been found that many banded lines that previously had a fault, have not become unbanded as a result of the fix, so they had to have a DLM reset on purpose.
Message 16 of 19
Hmm, partly true. It has been found that many banded lines that had previously had a fault have become unbanded as a result of DLM doing its job.
Techwizz
Message 17 of 19
True, I never said that DLM hasn't done its job at removing banding on every banded line!
Message 18 of 19
I never said you did!
I was pointing out that DLM would normally be left to do its job and that the moderators would not necessarily become involved at this stage where as you suggested that they might.
Techwizz
Message 19 of 19
Well, sorry my bad.
