Have you tried connecting to the test socket with a filter? Also do a quiet line test, 17070 option 2 best with corded phone. Any noise report a line fault on 151.
Can you post stats from hub. If hh6 then advanced settings then technical log information
is your router dropping internet connection when you drop connection to your devices?
