Coastal
Message 1 of 14
BT Infinity - line calibration and possible speed issue?
Hi,
We recently had BT Infinity installed (14-03-2013) and the speed has dropped significantly from 37 to about 20mb
Up load seems fairly consistent at 8mb
The engineer told us that the line calibration should only take 24hrs so I'm hoping there is an issue and that we can expect better than 20mb
We've been told to expect at least 25mb although it would be nice to get more
Can you advise how long the calibration should take and maybe check to see if everything is OK?
We have had to reset the router a couple of times
Please advise
Thank you
TEST_DATETIME_ZONEDOWNLOAD_MEGABITSUPLOAD_MEGABITSLATENCY_MSSERVER_NAMEDISTANCE_MILES
3/14/2013 9:18 AMGMT37.418.48London50
3/14/2013 9:38 AMGMT37.288.436Maidenhead0
3/14/2013 11:48 AMGMT37.58.310Maidenhead0
3/14/2013 12:00 PMGMT37.468.1710Newbury0
3/14/2013 1:53 PMGMT24.378.274Maidenhead0
3/14/2013 2:34 PMGMT16.698.2510Maidenhead0
3/14/2013 2:37 PMGMT15.758.2711Maidenhead0
3/14/2013 2:52 PMGMT20.768.1511Manchester150
3/14/2013 4:51 PMGMT23.358.2410Maidenhead0
3/14/2013 6:05 PMGMT25.228.1710Newbury0
3/14/2013 7:31 PMGMT26.058.278London50
3/15/2013 7:50 AMGMT17.468.1310Manchester150
3/15/2013 8:33 AMGMT25.828.26Maidenhead0
3/15/2013 1:31 PMGMT25.458.322London50
3/15/2013 5:24 PMGMT24.478.1610Newbury0
3/16/2013 9:04 AMGMT19.548.1310Cowes0
13 REPLIES 13
Guru
Message 2 of 14
Re: BT Infinity - line calibration and possible speed issue?
It looks as if there is noise on your line and DLM is reducing your speed.
Try a quiet line test (17070 and option 2 I think).
You could have wrong internal wiring.  Check if you have any extensions (telephone extensions, SkyBox, alarms etc) that are wired from a junction box between the incoming telephone feed and the master socket (where you modem should be connected).  If so, post any details and we will suggest what to do next.
Guru
Message 3 of 14
The router or the modem (White box)? If you've restarted the modem that would be why the speeds have dropped.
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
Coastal
Message 4 of 14
We were told by the BT engineer that if we suffered a loss of broadband that we should power off both the router and the modem, so far I have had to power off the modem once and the reset the router twice
I questioned the engineer about powering off whilst our line is being calibrated and he said that powering off and resetting would not make a difference - did seem a little strange to me!
There are no extensions or alarm cables or sky etc to the master connection which is where the modem / router are connected to so there should not be any noise or interference from within the house
We know that the line is capable of 37mb and only switched off the modem on the advice of the engineer due to a drop out of service
I won't switch off the modem any more
I have also heard that the Homehub 3 can be a little unreliable, although it is early days?
I have a TP Link TD-W8960N which has not let me down for continuity of supply - is this approved for use with Infinity?
Coastal
Message 5 of 14
Quiet line test seems OK
latest speed test;
3/16/2013 12:52 PMGMT22.077.510Bournemouth50
Guru
Message 6 of 14
You should never restart the Modem in the first 10 day period. In the first 10 days it will gather line Information then after it has enough on all levels it will decide where your line performed best at and set it at that speed. It will then continue to monitor the line forever and make adjustments. The reason why it's important that you do not disconnect the modem as the Cabinet (DLM) will not be able to make connection with the modem meaning it is recording this and will compensate by lowering the speed until it has a connection. Also turning it off suddenly can cause error bursts on top of that, so it is vital you give your line the best history that you can give it.
It will always look at previous history it has and make decisions from it. If it has bad history at the start it's very reluctant to actually improve the speed in future because it's seen it's not had good history in the past.  So it will slowly rise the line speed from 12Mbps to lets say 28Mbps. It will increase it increments due to your bad line history, if it has good say you maintained connection for 90 days and you suffered from a power cut and this put your speed to 20Mbps. Over the next 5/7 days you will normally see it jump straight up back to that speed. If you have bad history it will put the speed up slower and it can take 2/3 weeks for it to actually increase the speed as well.
Coastal
Message 7 of 14
Thanks for the info
Is there any chance of restarting the line monitoring?
Seems like we were given completely duff information by the so called 'engineer' from Openreach
Would be nice to start with a clean history and connection rather than have the system restrict the line due to us believing we were doing the right thing
Sounds like the 'engineers' need a refresh course on the technology as this one obviously didn't have clue and he'll continue to go round causing customers unnecessary issues
Please advise
Many Thanks
Guru
Message 8 of 14
You would have to get a DLM reset which requires a Engineer to visit your property and he has to decide to-do it.
Coastal
Message 9 of 14
So how do we go about requesting a DLM reset?
Is this something that BTCare can do for us ? Given that we are only in this situation because the engineer advised us incorrectly
Wouldn't an engineer of quality want to do this to make up for the other engineers inadequacy
We are down to 17mb
Guru
Message 10 of 14
You could request it but I doubt you will get anywhere until you hit below 12Mbps.
You could put you would have 2 push hard in my opinion.
