smurf001
Message 11 of 13
Re: BT Infinity lower speed than standard broadband with Homeplugs
Okay, thanks.
I don't understand why the homeplug had a higher download speed before infinity.
Are there any other alternatives to homeplugs or wired?
Message 12 of 13
wifi extenders but you need to try with wired conenction and eliminate homeplug as your problem
smurf001
Message 13 of 13
Okay, will see if I can find a way to connect a computer direct to the Homehub.
I do know I get a better speed when I am connected wirelessly direct to the hub, but pre infinity I had the same speed connected wirelessly to the hub or wired to the homeplug.
