MattOfSurrey
Message 1 of 15
BT Infinity package speed going down
Hi All,
We found an offer on BT to upgrade from standard Broadband to a BT Infinity package with average speeds of 36Mb per second at a great price for 18Months. Well we jumped at it and sure enough when we connected we were getting downloads of 30Mb+ which was consistent and superb. About a month later it was disconnected (Orange flashing). So we put in a call and soon we had a engineer calling. He explained that whoever wired it up had put two wires into one (whatever that meant) and so changed it. The speed dropped to 18Mbs - 20Mbs. Then we had a issue where it dropped to 10Mbs. Well this was totally unacceptable though the online checks it said there was no fault found. I chased the call and was assigned a visit by an engineer. This never happened as they found a fault and the speed went back up to 18Mbs. This is now constant. My point is that I was signed up for 36Mbs (Average) and I'm now getting 18Mbs and the call is closed. Is it possible that I may get up to 54Mbs at any point or do I now have to accept a near half speed drop from my original speed from now on?
14 REPLIES 14
Message 2 of 15
Re: BT Infinity package speed going down
as you say the 36mb is an average with some customers getting better and others lower hence an average   enter your phone number and post results remember delete number but leave exchange and cab  this will show range of speed for your line   https://www.btwholesale.com/includes/adsl/main.html
can you post stats from hub  if hh6 then advanced settings then technical log information
have you checked for line noise  dial 17070 option 2  should be silent apart from announcement and best with corded phone
MattOfSurrey
Message 3 of 15
Hi imjolly,
Thank you for your prompt response. Please see picture for the data. Please note that for the first month we were getting 30+Mbs before the engineer rewired us. bbchecker.png
Message 4 of 15
Estimated range is 31/19mb according to dslchecker
can you post hub stats. If hh6 then advanced settings then technical log information
are you using test socket with a filter to see if that helps
MattOfSurrey
Message 5 of 15
Hello again,
Please find the log below
Message 6 of 15
Nothing showing. It is not the log but the information with connection stats
Moderator
Moderator
Message 7 of 15
Hi @MattOfSurrey ,
Please can you post back with the connection stats?
If you are using the BT Smart hub you can get your connection stats by, Opening a new web browser on your connected device and type 192.168.1.254 or bthomehub.home into the address bar. This will open the Hub Manager.  Click Advanced Settings’ and then ‘Technical log.
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
MattOfSurrey
Message 8 of 15
Hello PaddyB,
I can get to the Technical log. It says there are 153 pages. I can save them as a ".csv" file but I cannot attach a file. It does allow a filter to certain events that dramatically reduce the size of information.
Please suggest how to proceed.
Kind regards
Matt
Message 9 of 15
It's not the actual log it is the technical log information page. Shows connection stats noise margin etc
MattOfSurrey
Message 10 of 15
Hi PaddyB,
Thanks to ijolly here is the information below.
This is a list of your BT Smart Hub settings and current statistics.
Product name:
BT Hub 6A
Serial number:
+084316+NQ82653921
Firmware version:
SG4B1000B540
Firmware updated:
21-Sep-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 3 Hours 35 Minutes 11 Seconds
Data rate:
5.74 Mbps / 20.00 Mbps
Maximum data rate:
5744 / 23965
Noise margin:
6.7 dB / 8.6 dB
Line attenuation:
27 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
8344 MB Uploaded / 52610 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-C2GS
2.4 GHz wireless channel:
Smart (Channel 6)
5 GHz wireless network name:
BTHub6-C2GS
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
A8:9A:93:2A:9E:2D
Software variant:
Boot loader:
9.2.0
